This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #8341
    Originally posted by Slippz
    I have one question. Just got Keskin kt1 16x9. Could you help me how to fit them on my e30, what tires should i take, spacers, and stuff? 2 rims with ET15 and 2 with ET 25. Btw, i have iX fender flares, so it can not be rolled...
    I was considering to use 225/40 rear, and 215/40 front tires, or maybe i should go with 215/40 all around?
    Thx!
    Put the ET15 wheels on the rear. Mount the ET25s up front with a 15mm spacer. 205/45 all around is best.
    • Slippz
      • Jun 2015
      • 5
      #8342
      Thank you, i'll do it!
      But isn't it ugly to put ET15 rear, and ET25 front?
      One more question, if i put 15et with 5mm spacer at the front, and 25et with 10-15mm spacer on the rear, how it works, will it rub?
      In the future i will probably remove iX fender flares, so i could roll fender and what setup you suggest then to make it look better?
      Thank you once more, and im sorry for being annoying...
      • JRKOUPE
        • Dec 2004
        • 3159
        #8343
        ugly?.....
        in general when running staggered set up....the wider look/track/deeper dish goes in the rear.
        r u confused re et?
        • Slippz
          • Jun 2015
          • 5
          #8344
          Originally posted by JRKOUPE
          ugly?.....
          r u confused re et?
          ohh, my bad... soz
          • fporro
            • 1859
            #8345
            How about a 87 cabrio with oem body, e30 5 lug swap and coil overs ?
            running 205/50/16 with 15mm front hub centric spacers due to bbk, but it only needs 6mm at most.
            Thanks.
            • getouth
              • Jan 2010
              • 3343
              #8346
              Wanting to run 17x8 et 35 ACS type1 with 20mm adapters. Lowered on Billy sports and low tec 60/50mm kit. Tires are summitomo 215/40's all around will it work?
              FEEDBACK:
              http://www.r3vlimited.com/board/showthread.php?t=316212
              BMWCCA #398608
              IG @yagayo38
              "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
              • Zesty Bonanza
                • Apr 2011
                • 80
                #8347
                225/45s at the tallest and with rolled rear fenders. Unless it's an early car then no roll.
                Do early model cars have wider wheel wells?
                I have a 1985 325e body with Hartge Type A 16x7.5 et25 wheels and would like to know the widest square setup (for tires) that I can use. From reading the forum it seems that 225/45/16 tires will fit except I don't know about the early model vs late model wheel well difference.
                Thanks.
                • Mystikal
                  • 9602
                  #8348
                  Thanks.
                  I have no idea what you're asking.
                  • Mystikal
                    • 9602
                    #8349
                    205/40s and it'll fit perfect. 215s will rub.
                    • Mystikal
                      • 9602
                      #8350
                      Thanks.
                      Yes, early cars have several mm more space for rear tires. But with either a late or an early car, your wheels can fit 225/45/16s all around without modification.
                      • ian e30 318is
                        • Mar 2007
                        • 1804
                        #8351
                        Jay, I will be switching to e30 M3 5-lug with 17x8 and 17x9 Style 32's (et20/26 respectively). I am decided on running 235/40 in the front. My question is what size to run in the rear with the 9". I would like to run a 245/40, but they are hard to match. Just FYI, I am heavily rolled in front with no fender liner and heavily rolled in rear with upper bump hammered out, so maybe 255/40 might work? Height adjustable as well on suspension with fairly stiff spring rates. Thanks for the help.
                        1991 LS1 Swapped 318is
                        Instagram:
                        https://instagram.com/saltybeast/
                        LS Build Thread:
                        https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                        • spisio
                          • Jul 2015
                          • 4
                          #8352
                          Great thread, finally registered to ask a question.
                          1991 318is, stock suspension and 17x7 et40 wheels with 205/40 tires. What size spacers would be best?
                          • mbonanni
                            • Sep 2011
                            • 6236
                            #8353
                            16x8 et 23 18mmf/20mmr adapters with 205/50. On coilovers with camber plates in the front.
                            Sent from my SM-N900P using Tapatalk
                            • Mystikal
                              • 9602
                              #8354
                              IMO, nothing larger than a 215/40 will work up front. 235/40 rears is also pushing it.
                              • Mystikal
                                • 9602
                                #8355
                                Ideally, 25mm. But they're heavy and expensive. 20mm all around is good.
