	This is a sticky topic.
 Thank you, i'll do it!
 But isn't it ugly to put ET15 rear, and ET25 front?
 One more question, if i put 15et with 5mm spacer at the front, and 25et with 10-15mm spacer on the rear, how it works, will it rub?
 In the future i will probably remove iX fender flares, so i could roll fender and what setup you suggest then to make it look better?
 Thank you once more, and im sorry for being annoying...Comment
 ugly?.....Thank you, i'll do it!
 in general when running staggered set up....the wider look/track/deeper dish goes in the rear.
 r u confused re et?I love sitting down and just driving!Comment
 Wanting to run 17x8 et 35 ACS type1 with 20mm adapters. Lowered on Billy sports and low tec 60/50mm kit. Tires are summitomo 215/40's all around will it work?FEEDBACK:
 http://www.r3vlimited.com/board/showthread.php?t=316212
 BMWCCA #398608
 IG @yagayo38
 "The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
 Do early model cars have wider wheel wells?
 I have a 1985 325e body with Hartge Type A 16x7.5 et25 wheels and would like to know the widest square setup (for tires) that I can use. From reading the forum it seems that 225/45/16 tires will fit except I don't know about the early model vs late model wheel well difference.
 Thanks.Comment
 Yes, early cars have several mm more space for rear tires. But with either a late or an early car, your wheels can fit 225/45/16s all around without modification.Do early model cars have wider wheel wells?
 Thanks.Comment
 Jay, I will be switching to e30 M3 5-lug with 17x8 and 17x9 Style 32's (et20/26 respectively). I am decided on running 235/40 in the front. My question is what size to run in the rear with the 9". I would like to run a 245/40, but they are hard to match. Just FYI, I am heavily rolled in front with no fender liner and heavily rolled in rear with upper bump hammered out, so maybe 255/40 might work? Height adjustable as well on suspension with fairly stiff spring rates. Thanks for the help.
 1991 LS1 Swapped 318is
 Instagram:
 https://instagram.com/saltybeast/
 LS Build Thread:
 https://www.r3vlimited.com/board/for...s-e30-ls1-swapComment
 IMO, nothing larger than a 215/40 will work up front. 235/40 rears is also pushing it.Jay, I will be switching to e30 M3 5-lug with 17x8 and 17x9 Style 32's (et20/26 respectively). I am decided on running 235/40 in the front. My question is what size to run in the rear with the 9". I would like to run a 245/40, but they are hard to match. Just FYI, I am heavily rolled in front with no fender liner and heavily rolled in rear with upper bump hammered out, so maybe 255/40 might work? Height adjustable as well on suspension with fairly stiff spring rates. Thanks for the help.Comment
