Originally posted by crzylildude
View Post
This is a sticky topic.
Originally posted by pretentious-pasta View Posthi i was wondering if a set of 15x8 et25 with 225/55r15 or 215/55r15 will fit a 89 coupe on mild lowering springs (going for an old school street racer look so it doesn't matter if they stick out a little)
these are the wheels http://www.ebay.com.au/itm/15x8-Axis...16.m2518.l4276
Originally posted by TheWipprSnappr View PostIve got a 1990 325ix dropped apprx 1.5" from stock currently with oem 15x7 et41 basketweaves on 195/65/15s. Will my ix fit 15x8 et25 konig widopens with 195/55/15s or 205/50/15s without hitting the struts or wheelwell liner or having to roll the fenders?
Thanks for reading
I have a 91 325i, ls1 swapped, doing a 5 lug swap with z4 rear hubs (5mm+). I bought style 32 17x8 et20 17x9 et26, I am looking for what tire I can run.
I was thinking to run 235/40 r17 front and 245/40 r17 rears. they are both very close to each other and about 24.5" diameter.
Will it work fine?
I was looking at proxes r888LS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
Fit question (2 different sets, same tire sizes):
205/55/15 (both sets). 1989 325 convertible lowered on H&R Sport w/ 15mm drophats up front.
Looking for info on fit of the following wheels:
15x7 ET10 (with 205/55/15)
15x8 ET20 (with 205/55/15)
Fit prognosis?Last edited by phenryiv1; 07-22-2015, 12:28 PM.
Wow ace thread.
I have a 1989 325i coupe and I am new to mods.
I would like to lower the 60mm and 40mm and I would like to add borbet type A 16inch 4x100 j9 et15 all round.
Would I need to use spacers?
Will my wheels rub on anything?
Will the wheels still point straight?
Will there be any camber issues?
Will I need to use spigot ring things?
Hope you guys can help.
Js
Sent from my Nexus 4 using Tapatalk
Originally posted by apiazza2010 View PostI have a 91 325i, ls1 swapped, doing a 5 lug swap with z4 rear hubs (5mm+). I bought style 32 17x8 et20 17x9 et26, I am looking for what tire I can run.
Will it work fine?
Originally posted by phenryiv1 View PostFit question (2 different sets, same tire sizes):
Fit prognosis?
Js
No.
If they did before.
If there were before.
If the wheels require them.
Originally posted by Mystikal View PostZ4 hubs? Isn't that E46 stuff? What about the fronts?
Sent from my SM-N910T using TapatalkLS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
Originally posted by Mystikal View PostFirst might rub occasionally front and rear. Offset a bit too low, but 205/50s would work. Second setup fits.
Originally posted by Mystikal View Post3-5mm front.
No.
If they did before.
Will I need spacers on the front because I am fitting 9js? If I was to fit 7.5j on the front would I still need spacers? Is it normal to fit 9js all round?
Thanks again great help. JS
