	This is a sticky topic.
 Just too much wheel for the front IMO. You can tuck the rears inside the body easily with the high starting offset, but the fronts will take a lot of spacing just to get them off the struts.Comment
 Hi! Yes, I'm here and answering these questions for reasons beyond me. Nice to know I'm helping though!Hi Jay,
 I stumbled upon this thread while researching which wheels and tires to get for my newly acquired '89 E30.
 It is very impressing that you have been dealing out helpful advice through all those years to E30 owners.
 With 571 pages in this thread I was sure I could find the answer to my question in here, but after searching through the pages I did not seem to find a clear answer.
 I want Ronal LS 15x7.5 and a meaty tire, but while the majority of the 225/50 seem to clear fine, it seems there is the odd tire in this size which rubs.
 The car is lowered but I am not sure of how much.
 I would like to use R888 tires, which I can get in a variety of sizes.
 The most interesting sizes to me seems to be 215/50, 225/45 and 225/50, where the latter size is the more expensive.
 The 225/45 seem a little undersized, so it may not be the best choice.
 So the question is would a 225/50 R888 fit without rubbing, or should I go with the slightly cheaper and perhaps safer size 215/50?
 The key specification for the Ronal LS is 9.2". This is the listed section width of a tire on a 7" rim (typically for most 215 or 225 tires), and is the largest that will fit without rubbing. The old Falken 512s that easily fit? 8.9". Falken 912? 9.0". Hankook R-S2? 9.2". Old-school Bridgestone S-03 that DID rub? 9.3".
 I looked the 225/50 R888 up and it's a 9.1". Should just work.Comment
 I am lowered on H&R blue springs with Konis. How will 17x8 et 20 all the way around fit? If they fit, what tire size is preferred. Thanks for all your information by the way, most forums are filled with e-thugs and "search" bullies!
 DTI can access 4.6 Ford engines, 5.0 Coyotes, 4.8 and 5.3 LSX swaps. PM me if you seriously need one.Comment
 No one said I'm not an e-thug. Go fuck yourself.
 ;) For zero rubbing, 205/40. If you have access to fender rolling in the back 215/40 will just work.Comment
 Hey Jay,
 First off thanks so much for doing this. Your the MAN! If i was in the toronto area id definitely just have you handle this for me, but since i'm in Portland all i can do is say thanks a ton.
 Recently purchased 1991 318is
 Buying some raceland coilovers when i buy my wheels.
 Iv got a place to roll fenders if/when necessary. just want to know if its going to need a lot of roll or not.
 I don't mind a BIT of stretch on my tires
 Either:
 Klutch 15x8.5 / et17 / 4x100 195/50
 Klutch 16x8.0"/et15/4x100 (open to tire size suggestions).
 Thanks again.Comment
 Little to no fender rolling with either setup. You could even go 205/50 on the 15s. 205/45 will be perfect for the 16x8s.Hey Jay,
 Either:
 New to e30 wheel/tire fitment. Need some help.
 How's it going. Thank you for creating this sticky. Hopefully you can lend some wisdom.
 Just bought an 89 325is for my younger brother. Ordered a set of Diamon Racing steelies for the car. 15x7 et0 in black. Car is on an adjustable coil over set up and can be played with. I want to order a thick set of rubber for these wheels without ordering radials. How big can I go? Previously had 225/50/15 on 4 lug style 5s on my vert with same suspension. Tires were too thin. Was worried I'd bend a wheel and had to slam the car to close the gap.
 My mechanic has suggested going up just a little bit to 225/55/15. Just want the car to sit comfortably. He is a new driver. Want something that will protect against bent wheels and close the gap.
 Any advice appreciated. Thanks in advance.
 MaxComment
 '89is h&r sports with blisteins shocks, 4x100 BBS RM 0012 15x7.5 et20 fronts and 15x8.5 et8 rears, will these fit without rolling the fenders,if so will they poke out a lot? i want a bit of aggressiveness but i dont want to look weird with my tires sticking out....help!!
 thanks in advance!Comment
 Terrible offset choice for an E30. You will have to run 185 or 195s, and it will still rub sometimes. I'd suggest selling them.How's it going. Thank you for creating this sticky. Hopefully you can lend some wisdom.
 MaxComment
