	This is a sticky topic.
 With stock struts or coilovers, those will clear without spacers. Depending on your bag setup you might need front spacers. 195/45 and 205/45 would work well for aired out fitment.When it comes to offsets, I'm completely clueless. I have a 1991 bmw 325i right now and I'm on the hunt for new wheels. When I was younger I always wanted an e30 with bbs-rs wheels, so that's what I plan to get. I currently found a set that is 8.5 and 9.5 size 16" with +15et. Does anyone know if that will fit fine? Will I need to buy some spacers?! And as for the tires, my car is currently bagged so I would like it to sit somewhat flush when it's aired out.
 The old setup I had was...
 17x8 et33 in the front
 17x10 et20 in the rears
 I also had adapters on the car which obv pushed the wheels out more but I forget what size they were...
 **The wheels I am planning to get are 4x100 so adapters won't be needed. If anything, I will need spacers if it doesn't clear something.
 long story short...I just want to know if those spec wheels will fit my car without a problem. If they won't fit, what size spacers will I need and what size tires will I need?!
 appreciate any and all help :DComment
 Yep, 215/60 was a popular mod back in the day. I think the 205/60 Federal 595 is the best wider than stock 14" tire available now, though.Comment
 Awesome, thanks! I was just about to browse this thread but I may as well ask you- what would be needed to fit 15x8 0 off set wheels? I'm considering getting another set along with the 14's. Not against fender rolling either to get the 15's to fit. What tire sizes would you recommend for the 15's besides 225/45 (incredibly difficult size to find in Canada)?
 EDIT:
 Actually nm looks like they will fit with 205/50 but lots of fender rolling/pulling probably required (I have a later model). I guess what I don't know without test fitting them is what size wheel spacers I'll need?Last edited by Mushroom Stew; 03-03-2016, 11:24 AM.Comment
 thanks man! :D:D
 I'm gonna order em, test fit em and if worse comes to worse, i'll get some spacers!Comment
 Greeting wheelmathicians, I need to know asap if a 17x9 et 20 will fit a late model with a hard roll and no pulling on the rears I'm on coils with a 650lb spring/billy sport. tire will be a 215 40 17 yoko Sdrive.
 Thanks!FEEDBACK:
 http://www.r3vlimited.com/board/showthread.php?t=316212
 BMWCCA #398608
 IG @yagayo38
 "The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
 What size tires would I run if I put 16x7 +20 Style 29s on my car with 18mm adapters? Final offset +2. Currently have 16x8 +5 (adapters) Style 5s with stretched tires and am trying to get away from it a bit and go with another OEM wheel. Maybe a 215/45 would be a good meatier tire?Comment
 So I picked up an e36 TI msport and bought a set of ACS typeII monoblocks. 17" 8.5 et15 and 9.5 et 22. I test fit them and they clear but poke more that I had thought they would. I'm unsure on tire size. Input would be greatly appreciated.Looking for a 3.46 or lower LSD. Lets make a deal.
 LSx e36TI coming soon
 Originally posted by s0urceMan, she'd be so easy to rapeComment
 86 325e
 4x100
 18mm (.7inch) adaptors
 Can someone fill me in on offset?
 They're 17 inch, looks like 9 and 8 staggered
 what size tires should i get
 thanks in advance
    Last edited by fenwick; 03-13-2016, 08:10 PM.Legit Sellers: Insomniac912, SixerFixer, 3liter6, NoSnowJustIce, JustXtreme, SLEEPYDUB Last edited by fenwick; 03-13-2016, 08:10 PM.Legit Sellers: Insomniac912, SixerFixer, 3liter6, NoSnowJustIce, JustXtreme, SLEEPYDUB
 Is it a late model 318 or early???
 Pretty sure that'd fit without rolling in the rear, the front may require a ~5mm spacer depending on the coil/collar/spring's relationship to the wheel.
 I think 205/50 is perfect on an 8, that's what I'm running, 16x8 et20 with spacers making effective et 13F 10R but my fenders are rolled, also a late coupé and I don't know specifically know about sedans.-Christian
 '37 Chevy pickup, the über project Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list. Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.Comment
