So i bought ix weeves when i had my ix, now i have an 87 i. I tried to put the ix weeves on the i and it hit the front strut towers. These are ix offsets and im not sure what size of spacer i would need and how safe it is to use them on a daily. I need to figure this out fast as i have my studs on still and its now past the removal date here in oregon, and dont want or need a ticket. Please help. Tires are 205/55/r15
This is a sticky topic.
Not really a fitment question, just how a tire will fit on the rim question.
I'm throwing together a 91 GTi for my wife as a surprise birthday present and need to get tires for the 16x7 wheels. OE rolling diameter is 22.6, I was looking at (recommended by local VW shop) 195/50r16 or 205/45r16. I know they both will be slightly larger in diameter than stock but which would be better for the car?
I know it's a dub in question but I figure I'd get a better response here than stretch dubs anonymous.
Thanks09 BMW 328xi touring 6spd
05 Subaru Outback XT 5spd
87 BMW 325is
a few bicyclesComment
Hey there guys I have a question....
I have brought wheels to fit my 1989 318i done a 5 lug swap running e30 m3 front struts....In the back using a e30 m3 hubs but don't know a good coilover system that works...(and don't know if I'm going to make it a true system as well)
As for wheel specs ill be running 18x8 in the front with 20mm offset and in the rear 18x9 24mm offset...doing a brake upgrade as well but don't know what to run as well for clearing the rim and performance with my s54 swap
I'll appreciate if you guys can also tell me what's a good size tire to run with them..was thinking of 255/55/18
Diff is a 3.73 lsd with a 420g Getrag 6 speed
CHEERS GUYSComment
Any FIRST HAND experience with 205/60r15 on Euroweaves?
Yes I know they are a larger diameter then stock. Yes I know 205/55r15 is the equivalent size I should run.
Here's my setup. Think I have a chance of making these fit?
- Euroweaves (15x7 - ET 24)
- Early model (high rear arches)
- Mild drop with H&R Sports.
- 4x 15mm spacers I can run if needed.
- E90 drop hats in the front, which I can take out.
- E30 M3 offset CABs (which push the front wheels forward)
I'm ok with mild rubbing at full lock.
'87 BMW E30 325is Turbo
'99 BMW E36 M3 - - - '98 BMW E36 328iComment
Early model, looking to fit the widest meats possible on my fzero1 fatlaces. 15x8.5 et15 fronts, 15x9.5 et15 rears. Willig to roll fenders, not looking to pull fenders.Jah bless! :pimp:Comment
Definitely will need a rear roll. Should be fine otherwise.Apex Arc-8 (17x8 ET25) running Toyo R1R 245/35 tires, any fender rolling to be worried about? Car is on AST coil-overs and lowered ~2" (I think, car is new to me so I'm estimating...). I definitely don't want the car any lower, if it makes the fitment work I am happy to raise the ride height a bit. Car is an 89 325is if it matters.Comment
Yep, that fits fine without spacers.hey Im new here, and im sure this has been answered but I cant find it via the search....
looking at buying a 92 325ic
lowered on h&r/bilstein
I have a set of BBS RM 15x8 ET14
I believe 205/50/15 would be best for this car, question is, will I need spacers and what size spacers should I get?
any pics would be awesome.
thanks!Comment
205/45 all around. Just a rear roll, no spacers.Year: '92
Model: 325ic
Suspension: IE race, Bilstein Sport, IE adj camber plate front, rear subframe with camber / toe adjust
Wheel Data: 8x16 et18, 8.5x16 et12, 4x100 cb57.1 widened steelies
Fenders are currently not rolled but am not averse to it.
Do I need spacers to clear?
What tire size should I run?
Thx in advance!Comment
No front spacers and 10mm rear would be perfect. You could run 215/40 as is or 235/40 tires with a rear roll."OK this might get complicated. Collecting all my suspension parts and wheels and its almost complete. Its a late model touring with Ground Control E30 5 lug swap kit up front. Z4 rear hubs pressed into the e30 trailing arms which I have been told move the hub out 2.5mm but I dont know if the GC kit changes anything up front. I have 17x8 ET38 wheels. What is the best tire size to use with out rubbing and not that much of a stretch and what spacers would I need. Its going to be lowered for street driving but nothing ridiculous. Thanks"
Ok so if my research is right the front is pushed out 12mm on each side and the rear is 2.5mm out with my set up. so 17X8 et38 and I was thinking 15mm rear spacers and roughly 5mm front? and 205/45/17 or 215/40/17? Sorry if this is a little complicatedComment
CBAKE
