	This is a sticky topic.
 You definitely bought the wrong wheels then. They don't fit properly at all, and will rub.I have a 87 325is I have 20mm adapters for my style 5's 17x8 et20 with solid offset control arm bushings. What size tire can I run the front and the rear has 12mm solid riser bushings for the subframe there for less camber. Im also running H&R Race Springs. I have roller fenders.. I plan on drifting and aggressively driving the car so NO RUBBING ALOUD!!!!!!!!! lolComment
 15mm front spacers.Okay guys, I need to know how much spacer I need. I ordered a set of kamotors ultrawides so I'm not too worried about poke, but here's the question. The wheels I got are a 17x10 square setup with a +15 et. I already run a 5mm spacer up front to clear basketweaves on my coilovers. What size spacer will I need to fit the fronts?Comment
 205/50 for sure.I'm looking at possibly running a set of klutch sl1's in a 15x8.5 et17 spec. What tire size would be best? Ideally I'd like to run a thicker sidewall 50/55? Thoughts? My car has the gc coilover spring kit/bilstein sports. Thanks in advance!
 Sent from my iPhone using TapatalkComment
 Should just squeeze by without rubbing. I'd suggest ANY tire but ASTs though, they are seriously awful.Comment
 Not possible without both stretch and rolling. 205/45 front 225/40 rear, rolled rears.Comment
 Paper thin strut clearance. 205/50 will work, 205/55 will probably touch the struts.Ok - looking to see if I can run this set up without needing spacers on my 1989 325i with a small roll in the rear. Currently on Billy/H&R spring combo. This will probably change.
 15x6.5 et 32 on a 205 tire
 or
 15x6.5 et 32 on a 215 tire.
 I calculated max back space for 15" is 131mm and with tires about 129mm. Seems like if i ran 215's and they were really 215mm, I'd have issues. Can you confirm?
 ThanksComment
 205/45 front, 215/45 rear, rear roll. Hubcentric rings.Comment
 Nope. And you live in America, land of internet purchasing. Nothing is difficult to find!90 325is with ksport coils
 rear: 16x9 et20, currently running 215/40/16 with 5mm spacers.
 I really want to move up to 225s on the rear, but 225/45s are laughably difficult to find. can I remove my 5mm spacer and run a 225/50 on the 16x9 without rubbing? I have some basic fender rolling done, but the 215/40s with the 5mm spacer rub with enough load.Comment
 First off. Thank you for your input over the years.
 Canadian people always helping out the homies.
 Currently running 16x8 +28 offset
 205/45 with h&r spring front / vogtland rears +20mm spacer (raises the car) because I drive a vert. Heavier in the back.
 Question: Do you think I could run 235s all around, already have fenders rolled very professionally done. ( I like square set ups)
 Thank you in advance.Mid life crisis.
