	This is a sticky topic.
 [QUOTE=Malcolm206;4668508]Et10. I run 15x8 et22 and on the right driveway my front right will scrape the fender a little bit.
 Stock fenders?Comment
 [QUOTE=pepperjackdaisy;4668514]
 Stock fenders. Once I roll them it'll be fine and I'm pretty low on Bilstein sport springs and shocks
 Sent from my iPhone using Tapatalk1988 E30 325iC
 sigpicComment
 Sorry for repetitive questions, but what your opinion on spacers? If I'm understanding offsets right, I'm too far in at et10, what is an ideal offset for me, 8 wide, without fender work?Comment
 Other way around. Et20 is more conservative than et10 - et10 stick out further.
 Without fender work, I wouldn't go further than around et20.
 sigpicComment
 Thanks, I've been thinking wrong the whole time... No wheel/tire knowledge at all so it's a crash course of learning since I decided to make a change...which sucks cause I love the shakotans :(Comment
 In terms of 225/50r15, there aren't many tires available. 205/55r15 is the same approximate diamter, and there are many more options. http://www.tirerack.com/content/tire.../homepage.html is probably the best place to find what tires are available and you can check any size you wish.1988 E30 325iC
 sigpicComment
 I have some 16x8 etc 23 and 16x9 et 14, I'd like to put on my car. I'm looking to add a 15mm spacer to the 16x8 and a 10mm spacer to the 16x9.
 What's the biggest tire size I could run, to have minimal rubbing under the fenders. My fenders are already all rolled and I'm coil overs with camber plates.@IRON-E30 aka Edwin:DComment
 Looking at a set of BBS RS from ewheelworks
 16×9″ et0 (new 3″ lips)
 16×9.5″ et3 (new 3.5″ lips)
 Is this setup too aggressive for an E30?Comment
