This is a sticky topic.
  • Malcolm206
    • Jul 2015
    • 84
    #9001
    Originally posted by pepperjackdaisy
    Which measurement is throwing me off?
    Et10. I run 15x8 et22 and on the right driveway my front right will scrape the fender a little bit.
    1988 E30 325iC
    • JRKOUPE
      • Dec 2004
      • 3159
      #9002
      et 20 is the sweet spot on 8's......
      • pepperjackdaisy
        • Apr 2014
        • 11
        #9003
        So a 10mm spacer should cure this correct? At et10, will I rub without rolling fenders?
        • pepperjackdaisy
          • Apr 2014
          • 11
          #9004
          [QUOTE=Malcolm206;4668508]Et10. I run 15x8 et22 and on the right driveway my front right will scrape the fender a little bit.
          Stock fenders?
          • Malcolm206
            • Jul 2015
            • 84
            #9005
            [QUOTE=pepperjackdaisy;4668514]
            Stock fenders?
            Stock fenders. Once I roll them it'll be fine and I'm pretty low on Bilstein sport springs and shocks
            1988 E30 325iC
            • pepperjackdaisy
              • Apr 2014
              • 11
              #9006
              Sorry for repetitive questions, but what your opinion on spacers? If I'm understanding offsets right, I'm too far in at et10, what is an ideal offset for me, 8 wide, without fender work?
              • Malcolm206
                • Jul 2015
                • 84
                #9007
                Other way around. Et20 is more conservative than et10 - et10 stick out further.
                Without fender work, I wouldn't go further than around et20.
                1988 E30 325iC
                • pepperjackdaisy
                  • Apr 2014
                  • 11
                  #9008
                  Thanks, I've been thinking wrong the whole time... No wheel/tire knowledge at all so it's a crash course of learning since I decided to make a change...which sucks cause I love the shakotans :(
                  • Malcolm206
                    • Jul 2015
                    • 84
                    #9009
                    These links should answer any questions you have on wheels.
                    1988 E30 325iC
                    • Malcolm206
                      • Jul 2015
                      • 84
                      #9010
                      Originally posted by NC325iC
                      looking for a good tire recommendation. There seem to be far fewer options in my current tire size.
                      I am running a set of DForce LTW5 15" wheels. My current tires are 225/50/15
                      Street driving only, what size/brand/model tire would you recommend?
                      In terms of 225/50r15, there aren't many tires available. 205/55r15 is the same approximate diamter, and there are many more options. http://www.tirerack.com/content/tire.../homepage.html is probably the best place to find what tires are available and you can check any size you wish.
                      1988 E30 325iC
                      • Justen
                        • Feb 2016
                        • 87
                        #9011
                        No answer for my above question? Where is Mystikal when you need him?
                        • IRON-E
                          • 16548
                          #9012
                          I have some 16x8 etc 23 and 16x9 et 14, I'd like to put on my car. I'm looking to add a 15mm spacer to the 16x8 and a 10mm spacer to the 16x9.
                          What's the biggest tire size I could run, to have minimal rubbing under the fenders. My fenders are already all rolled and I'm coil overs with camber plates.
                          @IRON-E30 aka Edwin:D
                          • jchangy510
                            • Jan 2015
                            • 43
                            #9013
                            Looking at a set of BBS RS from ewheelworks
                            16×9″ et0 (new 3″ lips)
                            16×9.5″ et3 (new 3.5″ lips)
                            Is this setup too aggressive for an E30?
                            • mmoyer11
                              • May 2015
                              • 138
                              #9014
                              1990 325i, BC Coilover suspension. Enkei m1 16x7 +42 offset, 205/50 Yokohama S drives. How's the fitment? What would I need to clear struts?
                              • Malcolm206
                                • Jul 2015
                                • 84
                                #9015
                                Yes, et0 does not work on an E30 without fender flares.
                                1988 E30 325iC
