	This is a sticky topic.
 What about 16x8 et 20, stock 4 lug set up.
 225/45R16?Comment
 @ Staszek. That is the perfect wheel set up for E30 in my opinion. I have been running it for years. The only questions would be tire brand name. 224/45/16 Nexen may not rub up front, whereas 225/45/16 Goodyear may rub. Each manufacturer has their own specs.
 Sounds crazy but good luck. Cheers!Comment
 I asked this question earlier, but just stumbled on some new wheels for cheap.
 1989 325is
 Suspension
 Ground Control Street kit Coilovers
 Nasieg 5-lug conversion
 Front
 e36 M3 front hub (Pushes out +12mm)
 Rear
 z4 Hubs (Pushes out +2.5mm)
 Wheels
 e39 Fitment Style 32s
 Front - 17x8 et20
 Rear - 17x9 et26
 I have hubcentric 10mm, 5mm, and 3mm spacers on hand and can do a roll as well.
 What tire sizes am I looking at?
 Thanks!Comment
 You're still going the wrong direction. 12mm spacer means you should be running 12mm higher offset, not lower.The front strut is still e30. Not running anything e36 besides the hubs. It's effective like running a 12mm spacer. That's why I chose 17x8.5 et20.
 The 3mm spacer on the 16s is for caliper clearance, the apex won't need that
 For tires I chose
 215/45 front hankook rs3
 225/45 rear hankook rs3
 Will report back how they fit
 And the tires are all way too tall.Comment
 Stretched tires and no spacers. 205/40 front 215/40 rear AND a rear fender roll. They will sit flush.I asked this question earlier, but just stumbled on some new wheels for cheap.
 1989 325is
 Suspension
 Front
 Rear
 Wheels
 Front - 17x8 et20
 Rear - 17x9 et26
 Thanks!Comment
 Thx for the input.
 Front has a ~5mm gap between strut, so the offset is just right for front with the 5x120 sleeves. The tires are pretty tall but they just barely fit in the front. Comment
 Thanks I am looking at@ Staszek. That is the perfect wheel set up for E30 in my opinion. I have been running it for years. The only questions would be tire brand name. 224/45/16 Nexen may not rub up front, whereas 225/45/16 Goodyear may rub. Each manufacturer has their own specs.
 DIREZZA ZII STAR SPEC they have the same section width as the Nexen at 8.9"
 So hopefully that would work!Comment
 Jay,
 Any thoughts on how I could fit BBS RM's on my '92 vert? I know stock on the wheels is 15x6.5 et 33.
 I'm looking at a set that 8" wide with bigger lips. I'd want to have 3" lips on the rear. Would that work?
 Suspension is GC conversion kit.
 Thankssigpic
 Current:
 92 325ic Mtech 770
 99’ 528it
 Past:
 02’ 325it - 88' 735i - 88' 325ic - 89' 325is - 85' 325e
 90' 535i - 95' 530i - 03' 530i - 88' 325icComment
