This is a sticky topic.
  • estoguy
    • May 2013
    • 1087
    #9361
    Hey Jay... looking at a set of 16s... they are Momo, 4x100, 7.5X16, ET40. They would be coming with 205 60 R16 Bridgestone Ecopia... can these fit on an E30 running stock suspension?
    Estoguy
    • Mediumrarechicken
      • May 2017
      • 759
      #9362
      I'm looking to get some 6ul's, I've looked and looked on Google for pics. Thing is I've only come across ones that are running the miata version. I can't find the spec e30's is anyone running these wheels? Or something else i n a 15x7 15 offset
      • AusScare
        • Jun 2014
        • 220
        #9363
        What good 16x8 +20 wheels are available?
        Hoping to run 205/50 front and 225/45 rear, as well as RX7 calipers in the front.
        Does this perfect wheel exist?
        '90 318is
        • Jb325is
          • 2137
          #9364
          Don't think 949 ever actually released the 6UL for SE30. Most run Kosei K1, D Force, or the Jongbloed
          - '88 m54 coupe
          <3
          • Mediumrarechicken
            • May 2017
            • 759
            #9365
            They make them specifically for the e30, they have for a few years it looks like. http://949racing.com/15x7-6UL-SE30.aspx
            • hexe30
              • Jun 2015
              • 141
              #9366
              Looking at a 17x8.5 +35 offset. What can I do to get to them to work?
              • parkerbink
                • Jun 2004
                • 10137
                #9367
                Seems like the gurus have left the building.
                • Chrisv006
                  • 375
                  #9368
                  Could I run BBS style 29's with 18mm 5x120 adapter on a 1990 convertible, lowered about 1.5" with no rolling? What tire size would work?
                  • E30_Kyle
                    • Mar 2017
                    • 7
                    #9369
                    Looking to get a set of wheels. I plan on running 15x8 +38 in the rear and 15x7 +25 in the front. What size spacer/tire should I run for an aggressive fitment?
                    • LateE30
                      • May 2017
                      • 210
                      #9370
                      Will a 16x9 ET 25mm fit all around with 205/50/16's?
                      '87 Vert, Black, 5-sp
                      '15 Civic Si, White - Daily commuter
                      '15 MB C300 Sport, White/Cranberry - Wife's
                      • LateE30
                        • May 2017
                        • 210
                        #9371
                        welp. i suppose it does NOT fit...sad day.
                        Rears fit GREAT, couldnt be more perfect. However the fronts stick out a good amount from the fender AND they are rubbing the struts.
                        Going to get 5mm spacers and extended bolts. See if it at least fixes the clearance issues. i think a lower profile tire will be more useful as well, thinking a 45 or 40 instead of the 50mm.
                        I think it's going to look pretty terrible sticking out 5mm more up front
                        • Mystikal
                          Wheel Fitment Expert
                          • 9602
                          #9372
                          Originally posted by houstonf34
                          thanks, this is a great thing you are doing.
                          For autox and fitment would you recommend 205/50 potenza , dunlop direzza 225/45 or bfg rizal s 215/45
                          225/45 z2
                          • Mystikal
                            • 9602
                            #9373
                            Originally posted by Staszek
                            16"x8" ET29. Tires are 225/45R16.
                            What size spacers front and rear? 1990 325is on H&R Sport.
                            10mm front hubcentric. Rears can work with none at all, up to 5mm works without fender rolling. 10mm if rolled flat.
                            • Mystikal
                              • 9602
                              #9374
                              Originally posted by dailyrider
                              Huge thanks man. Great info. I ended up with a different set of wheels. Work 17x8/9 et 35 with 18mm adapters. Put 235/40 on the rear and 215/45 on the front...cause I nerded out about matching sidewalk height. Front clear with the roll and pull but I rub on the front of the wheel well. Rear is just about perfect. Going to try 215/40.
                              And yeah man no joke on the spring rates. Bouncy as fuuuug. I will be looking into your recommendation for sure.
                              Thanks again!
                              Nice. 205/45 would match better IMO.
                              • Mystikal
                                • 9602
                                #9375
                                Originally posted by Idrisu
                                Will this require spacers to clear the caliper?
                                front: bbs rs 039 16x7 et24
                                rear: bbs rs 040 16x8 et24
                                Shouldn't.
