This is a sticky topic.
  • bradmer
    • May 2016
    • 362
    #9436
    255 / 40R 17 square
    1987 e30 H&R race springs / Bilsteins / rolled fenders / liners removed / 17x8" Apex arc8 flat face wheel
    In reading up it looks like 255 fits the rears with a 17" wheel, what size spacer would be required to run them up front? Or can I make 245 work square with no spacer up front?
    I'm looking at the BFGoodrich Rival S 1.5 tire.
    Thank you
    • z168
      • 128
      #9437
      Originally posted by z168
      91 on eibachs
      17x8 ET20 - will I need spacers? Recommended tires?
      Followup question:
      How about 17x8 ET15? Wil this poke?
      • parkerbink
        • Jun 2004
        • 10136
        #9438
        These are 16x7 ET25, tires are 195 45 16. Are they sitting back or ok?
        • alpineE30
          • Aug 2007
          • 81
          #9439
          Z4 16x7 225/50 rims offset 47 with 318ti rear trailing arms? Do i need spacers still or will it fit? Front what spacers mm? Probably going to do 4x5 front spacers didn't decide that yet. But will be going 5 lug in the front eventually. early model btw.
          • sklbase
            • Aug 2013
            • 88
            #9440
            Mystikal-
            4x100, H&R race springs, Bilstein HDs
            What max size tire on Kopi Alpina reps 17" x 7.5?
            Thanks
            • Tree25
              • 118
              #9441
              hey mystikal, what size tires should I run for this wheel setup on my 1990 325is sitting on coilovers
              Front Wheels: 16" x 8"
              Rear Wheels: 16" x 9"
              Bolt Pattern: 4x100 /114
              Front Offset: 20 ET
              Rear Offset: 15 ET
              Center Bore: 73.1
              • sklbase
                • Aug 2013
                • 88
                #9442
                Originally posted by sklbase
                Mystikal-
                Thanks
                Sorry - this is on a 89 325i coupe
                • James_1991
                  • May 2016
                  • 32
                  #9443
                  Two questions. Both dealing with a '91 vert with bav auto springs and bilsteins.
                  Will RWD 14inch weaves with 20mm spacers all around be overkill?
                  Also what would be an appropriate tire for 16x8.5 with +15 without rolling fenders?
                  • '88v8
                    • Oct 2016
                    • 1
                    #9444
                    Looking at getting TRM C1s in 15x8 with 20mm offset
                    Trying to fit 245/40/15s all the way around, is this possible?
                    I have a 1988 325i with a Ford 347 stroker that I'm trying to keep from spinning everywhere.
                    • Rsully70sev
                      • 2391
                      #9445
                      I'm close to pulling the trigger on some Gotti 1001's but they're overseas and overpriced. I'd like to be reassured these will fit before I pull the trigger.
                      Specs:
                      Gotti 1001
                      16x8.5
                      5x120
                      et 21
                      Thoughts:
                      4x100->5x120 adapters 18f, 20r
                      Car:
                      88 e30
                      Rolled, not pulled
                      Rx7 calipers in the front
                      Thank you!
                      • LowR3V'in
                        • 4209
                        #9446
                        is mystikal still doing this?
                        • LowR3V'in
                          • 4209
                          #9447
                          double post.
                          Last edited by LowR3V'in; 09-21-2017, 07:34 PM. Reason: posts before this where deleted
                          • sklbase
                            • Aug 2013
                            • 88
                            #9448
                            His last reply was July 27th. He gets to it every now and then, I say be patient.
                            • Jowey
                              • May 2008
                              • 25
                              #9449
                              This weekend I have fitted 215/45/17 tires on 17x8.5 et25 with a 5mm spacer on the front with
                              H&R sport springs.
                              The rear is 215/45/17 tires on 17x8.5 et25 with a 3mm spacer and H&R sport springs.
                              Not rolled fender.
                              Hope this info help some of you.
                              Sent from my Pixel XL using Tapatalk
                              • crackerbme
                                • Aug 2017
                                • 5
                                #9450
                                1989 BMW 325i Wheel Fitment
                                I have a 1989 BMW 325i with CATuned coil overs. The rims I have are 16x8 with +25 offset. I know I have to at least run a 3mm spacer or they just skim the brake caliper. I have 3, 5, and 10mm spacers to use. My question is what size of tire would work with this setup? I have all new plastic in the front of the wheel well for the brake ducting to make it all nice and clean in the front so I would not prefer to trim it. I have test fitted the rims with all the different spacers and I am quite concerned that I have made a bad rim choice but yet I see lots of others out there who have made this work. I have also heard opinions that the 16x8 with a +15 offset is the perfect rim size for the E30, hence the reason I have 10mm spacers as well. I am not going for stretched tires on this build, I want to have a more performance tire on there with a tread wear of about 200, 100 would be too soft for daily driving but also don't want rubber bands. I don't mind rolling the fenders so long as it is just the inside lip as I want to keep the body lines stock, but finding someone in Edmonton to roll them with a fender roller might be tough. Any thoughts on this would be helpful.
                                Thank you.
