Hi all, I have a set of BBS RS 036 that are 4x114.3 and 15x7, and I believe they are et40, could I find adaptors? If so, where is a good place to look?
This is a sticky topic.
Originally posted by dude8383 View PostHey man,
So I've got a bit of dilema.
I bought 16 x 7.5 rims ET 25. One of them is done for.
I have two that are on their way now, but they're an ET 38.
What spacer would you recommend I run?
-Jay
so it seems like every1 who is running 16x9's is also running undersized tires. i want to know why i cant run a 225/45/16 tire on a 16x9 et7 front, and 16x9 et10 rear? and if its not possible, what is the closest to stock that i CAN fit. THANKS!IG: @Baye30
Originally posted by Mystikal View PostWell, 13mm would be perfect for obvious reasons. Since that's not exactly a common size, run 15mm spacers.
-Jay
Yes, a 13mm spacer would be ideal!IG: deniso_nsi Leave me feedback here
Originally posted by golde30 View Postso it seems like every1 who is running 16x9's is also running undersized tires. i want to know why i cant run a 225/45/16 tire on a 16x9 et7 front, and 16x9 et10 rear? and if its not possible, what is the closest to stock that i CAN fit. THANKS!
-Jay
Originally posted by dude8383 View PostIt won't push them out too much? Should I run the two with spacers in the back or the front?
-Jay
What about for cars with 5-ug swaps? (on facelifted cars, '88+)
I am doing the E36 M3 fronts and Z3 rears, and I am told E36 offsets are what work for wheels. Assuming this is correct (et41), I'm hoping I can run...
215/45/R17 on a 17 x 7.5 wheel (~.5" taller than stock)
or
215/40/R17 (~.2" shorter than stock)
...without rolling . Rolling involves squishing the underside of the lip to a sharper crease or actually pushing the whole arch outward? I assume most people are just squishing the inner part of the arch flatter?
Thanks!
"BMW Style 32 Poster-Child"
HTTP://WWW.CLAVINZERO.COM/e30-5-lug
**(My Guide to E36 M3/Z3 1.9L 5-lug Swap)**
Originally posted by Jesse30 View Postim getting 16x8 sportmax 501's tomorrow, and i was planning on running 205 45 16's on them.
im wondering if i should do 45 or 50. and if i'll need hub rings or a stud kit or anything of the sort.
You will need hub rings, and your stock bolts will be fine.
-Jay
Originally posted by clavinZERO View PostWhat about for cars with 5-ug swaps? (on facelifted cars, '88+)
or
Thanks!
Rolling is just squishing the lip, yeah. No visible difference from the exterior. The factory rear arches are half-rolled, take a look and you'll see what I mean.
-Jay
Originally posted by Mystikal View Post215/40/17 will be easier to fit. 215/45 is tall enough to cause issues with the fender lining.
-Jay
I was thinking that 7mm or so more towards the fender linings (from the ~15mm larger diameter) wouldn't be too bad. You think it will rub too much?
195/65/R14 Overall Diameter: 23.98 in 609.09 mm
215/45/R17 Overall Diameter: 24.61 in 625.09 mm
215/40/R17 Overall Diameter: 23.77 in 603.75 mm
I have a car on front of me with the 215/40s and the sidewall is scary small for these roads around here.
