This is a sticky topic.
I'm guessing by your reply you didn't find it, this is purely for tire size, not wheel size.
It gives you an idea of say how the overall diameter of a 195/50 comares to the stock 195/65 or a 205/40 to a 205/45.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
-Erik
Originally posted by 87e30I just want to dance with some beeziesComment
Will 17x8 et 20 and 17x9 et 22 with 235/40 17 Hankook rs2's fit? I know I will have to roll the rear just a little more then I have now. But not sure on the front.
Running 16x8.5 et20 front and 16x8.5 et22 with 225/45 16 rs2's now.Comment
I'm picking up some 16x9's et 15, does any one know how far I can space them out if I go with turbo flares? I want to run 225/45/16 all around.Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
OK. I got a set of 16x9 Borbet and can pick up some BFG G-Force Sports. Do these tires stretch ok? The fitment I am considering is:
215/40/16 in the rear.
205/45/16 in the front.
I sit on coilovers with rolled fenders...Is this a reasonable tire setup?Comment
or for the advanced user... This site has much more information about comparing two sizes/offset/everything.
http://www.rims-n-tires.com/rt_specs.jsp
But thanks to you, when I do find a suitable set of 16 x 9s I already know what tire size and offsets I can get away with. ;)Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
I'd go 205/45 all the way around.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Hey I'm getting some 16x9 Brock B1s this weekend (et 15). I will be running a bigger tire b/c I'm getting turbo flares. With the flares I want to space the rims out 10 mm up front and 17 in the rear w/ 225/45/16 KDW2s. Do you think this will clear w/ the IE flares?
I also wanted to know what kind of caliper clearance would I have up front with this kind of spacing? I ask this b/c I want to know if the rx-7/corrado brakes will fit underneath?
Mystikal I'd really appreciate your input, since those 17x8s didn't workout.Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
How much does the "poke" differ between a 16x8 et 0 wheel and a 16x9 et 7 wheel?
I'm not sure where the difference in wheel width comes into play.
thanksS50'd
Originally posted by TDE30What is this faggy shit I have happened upon?Originally posted by slammin.e28I can always live in a M3. Can't M3 a house.Comment
so id like to run stretched tired on my 15x8 RM's, but I don't want them to be like this..
I'd much rather them be like this...
and I'd like to know what tire size to run to achieve this look...
thanks alot.Comment
I had my wheels off today and measured from the mounting surface to the shocks and from the mounting surface to the fenders on both the front and the rear.
In the front I measured to the strut itself at 133.35mm clear and then to the lower spring pad at 98.42mm clear.
Will 17's and tires, with no spacers, be under the the lower spring pad?
Even when slammmed with coilovers?
Thanks for the help again...Comment
