This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #121
    20mm spacers. 14's are a bitch with those wide tires, because the strut angle is working against you.
    Jay
    • onaquest
      • Nov 2005
      • 805
      #122
      would these require major rolling?
      BBS RM
      fronts: 15x8.5 w/ 195/45/15
      rears: 15x9.5 w/ 215/40/15
      id prefer wider tires on these wheels, but those are the currently mounted sizes
      application is 90 325 with bilstein sports/ H&R sports
      http://bbswheels.blogspot.com
      • aworthybrother
        • May 2007
        • 899
        #123
        16x7 offset?
        what is the ideal offset for 16x7 for my 1987 325e?
        i am eyeing on a 16x7 et35. do i need hubcentric? is yes what exact size? i have stock suspension and will be upgrading to bilstein shocks SPORTS in the future.
        i did search but did not find any exact answer. Thanks!
        • Mystikal
          • 9602
          #124
          BBS RM
          Those wheels will be sticking way outside the fenders. The front offset becomes ET8, and the rears are ET-5. Because the tires are so tiny you actually might be able to get them on without flares, but the car will have be A LOT lower than H&R Sports to not look retarded.
          Jay
          • Mystikal
            • 9602
            #125
            ET25 or so for those wheels. ET35 will be extremely close to the struts, if you'd like to use those wheels run 15mm spacers and 205/50/16 tires.
            Jay
            • e30 Luv
              • Dec 2006
              • 395
              #126
              Jay:
              I picked up some iX basketweaves for my 86 with stock suspension. What size spacers would be good and whats a good tire size recommendation? Id like to have them sit at about like the ones in your sig but avoid any fender rolling if possible. Im also planning on upgrading the suspension sometime in the next year. TIA
              • Mystikal
                • 9602
                #127
                Originally posted by e30 Luv
                Jay:
                15mm spacers would make them fairly similar to Euro basketweaves, and leave plenty of room for 225/50/15 tires if you're interested.
                20mm spacers would make them fit like my wheels, and then you can pretty much rule out any 225 dreams without rolling the fenders FLAT. 205/55/15 tires would be fine with that.
                Jay
                • golde30
                  • 11464
                  #128
                  jay,
                  how much rolling to run 245/45/16 on a 16x8 et20 slipstream. im picking up M3ryans slips, and hes got those beeeefy ass tires on them. im not scared of a lil rolling. i read a couple threads where you said extensive rolling, but i just wanna know if we're talking like cuttin out metal. i am riding on 450/750 GC w/koni short bodys, so my ride is pretty damn stiff.
                  IG: @Baye30
                  • e30 Luv
                    • Dec 2006
                    • 395
                    #129
                    Jay
                    thanks :D i think im going to have to go for 20mm with 225's, it just sounds to good to resist. so does that mean i need all 4 spacers? or just 20's in the front and something else for the rear pair?
                    • Mystikal
                      • 9602
                      #130
                      Originally posted by golde30
                      jay,
                      Honestly, talk to Ryan.
                      I know for a fact that with 225/45/16 tires on Slips, you have to get the fenders rolled completely flat, AND have a stiff suspension. It's a very aggressive fitment.
                      With the 20mm wider 245s, you're looking at some serious work (especially on late models). But just see what Ryan did.
                      Jay
                      • Mystikal
                        • 9602
                        #131
                        Same spacer all around. I'm warning you right now, ET21 with 225s will need some good fender work.
                        Jay
                        • e30 Luv
                          • Dec 2006
                          • 395
                          #132
                          thats okay with me, a friend of a friend has a roller I can borrow. by good fender work you just mean as flat as possible right? i wont need to actually roll up the lip? (sorry to make you hold my hand through this, but I just want to have a clear idea of what im getting into.)
                          • Mystikal
                            • 9602
                            #133
                            Completely flat might do it.
                            I'm still struggling with my 225/50/15 R-S2s and 15x7 ET20 wheels. The fender is 80% flat and it's still rubbing quite severely during hard driving.
                            Jay
                            • 8atman
                              • Apr 2007
                              • 492
                              #134
                              are you rubbing due to soft spring rates or your et is to aggressive? I am shopping for the perfect rate for my e30 and with my 0et I will need to run pretty stiff. I have already rolled and pulled my fenders flat.
                              Thanks.
                              ash
                              • Mystikal
                                • 9602
                                #135
                                Thanks.
                                ash
                                The spring rate is 475lb/in linear, which isn't exactly soft for a 2800lb car.
                                The tires are too wide, the offset is too low.
                                Jay
