225/50/14 on caps or weaves?
    • 37833
    He is worried about inner clearance though.
    Grover Beach, California
    BimmerHeads.com
    • JoeMadoo
      • 936
      Ya, the konig's are farther in as well.
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • SchnellerVert
        • Sep 2005
        • 3948
        Why are you going to run a staggered setup anyway? It cost more and handling is better with a neutral or equal stance.
        The car is going to have a tendency to plow in the corners with this setup.
        • Mystikal
          Wheel Fitment Expert
          • 9602
          Originally posted by JoeMadoo
          Ok well a 15x7 wheel with an offset of 20 will actually reach in 1.35mm more than the 14x6.5 weaves and 7.7mm more than the bottlecaps with a +25 offset.
          The section width of your Kuhmo's are 9.1, and your average BFGoodrich tire is 9.2, so its not really any wider of a tire.
          But thats ok, your right.
          What are you talking about?
          A 7" ET20 wheel has 4mm MORE room inside than a 6.5" ET30 (stock basketweave).
          A 7" ET20 wheel has 3mm MORE room inside than a 6" ET35 wheel (stock bottlecap).
          Both of these facts are useless because a 15" rim has approximately a 6mm gain in clearance due to the inclination of the strut.
          So essentially, you have around 10mm MORE room inside than either of his options.
          I hope we're all better people now.
          -Jay
          • JoeMadoo
            • 936
            The stock rims are et25 aren't they?
            '86 E30
            '05 E53 X5
            '72 Firebird
            '10 Prius
            '03 Tundra
            • Mystikal
              • 9602
              No.
              -Jay
              • JoeMadoo
                • 936
                Ok sorry chief.
                '86 E30
                '05 E53 X5
                '72 Firebird
                '10 Prius
                '03 Tundra
                • JGood
                  • Jan 2004
                  • 7959
                  wow this thread went to shit.
                  I put the tires on, they fit, barely.
                  I'm doing a staggered setup because the tires cost me $200, with 1 autox on them. That's about $600-$700 worth of tires. I'll take the plow and keep my wallet. I'll still be faster then I was on my Azenis.
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • Mystikal
                    • 9602
                    Play with pressures. Inflate the rears much higher than the fronts, for example. Also if you have the option, adjust sways/dampers/rear height.
                    -Jay
