225/50/14 on caps or weaves?
  • JGood
    • Jan 2004
    • 7959
    I picked up (2) 225/50/14 and (2) 205/55/14 Kumho V710's. I have a set of weaves and a set of bottlecaps. Which wheels would I want to mount them on for best clearance? I know weaves are .5 inches wider, but is the offset so much different that it actually would put the tire closer to the strut? I guess I'll put the 225's out back, I don't think either wheel will fit them in the front. I'd prefer the weaves, so the sidewalls won't bulge on the 225's.
    Can't wait to see how she does with these tires :)
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • 34844
    I think weaves will be better, 225s are pretty wide already on them, it would be even worse for the cap.
    you can fit the 225s on the front with the weaves and a thin spacer (2-3mm)
    • JGood
      • Jan 2004
      • 7959
      That's my main concern, I don't want any rubbing, don't really have time to get spacers. I'll mount them on the weaves and put the 225's in the back.
      Thanks.
        • 34844
        with the really thin spacer it's not a problem. a stud kit is highly reccomended either way.. I got the vorshlag 57mm kit and it's fantastic. wheel changes are WAY easier now :D
        • Jean
          • 18228
          V710s are sticky as hell!
          • JGood
            • Jan 2004
            • 7959
            So wait, are you now saying they won't fit without spacers? I don't care if the 225/50's fit on the front, they are going on the back, and the 205/55's are going on the front.
              • 34844
              no, II'm saying 225s *might* rub on the front. what you are talking about works fine. I'm just saying that the small spacer isn't a big deal, especially with a stud kit (which I would get either way).
              • joshh
                • Aug 2004
                • 6195
                This is something I would measure out. Put the rims on and measure the distance you have from the plane of the rim up to where the tire would be at the shock.
                With the bottlecaps the stock tire is already pretty damned close to the shock.
                "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                  • 34844
                  I only know a small spacer is required because cheades runs 225s on his weaves and he needed one..
                  • JoeMadoo
                    • 936
                    I have 225/50s on 15" Konigs with a 20mm offset, and they dont rub at all. It's lowered 1.6" also.
                    '86 E30
                    '05 E53 X5
                    '72 Firebird
                    '10 Prius
                    '03 Tundra
                      • 37833
                      That really doesn't compare to the original poster's question at all. ;)
                      Grover Beach, California
                      BimmerHeads.com
                      • JoeMadoo
                        • 936
                        How does it not compare? I'm basically saying that if mine wont rub with bigger wheels, his wont either.
                        '86 E30
                        '05 E53 X5
                        '72 Firebird
                        '10 Prius
                        '03 Tundra
                          • 37833
                          He is talking about OEM 14" weaves and you are talking about 15" aftermarket wheels with a 20mm offset [which sit much further out than stock weaves].
                          BimmerHeads.com
                            • 34844
                            not to mention he's talking about competely different kinds of tires. I bet those V710s are waaay wider than any "street" 225 you'll find..
                            • JoeMadoo
                              • 936
                              Ok well a 15x7 wheel with an offset of 20 will actually reach in 1.35mm more than the 14x6.5 weaves and 7.7mm more than the bottlecaps with a +25 offset.
                              The section width of your Kuhmo's are 9.1, and your average BFGoodrich tire is 9.2, so its not really any wider of a tire.
                              But thats ok, your right.
                              '86 E30
                              '05 E53 X5
                              '72 Firebird
                              '10 Prius
                              '03 Tundra
