V710 won't hold air
  • JGood
    • Jan 2004
    • 7959
    V710 won't hold air
    I have a set of v710's, and 1 tire just kind of stopped holding air. It's a slow leak, maybe looses 2-3 psi per day. Any ideas? Maybe a remount/balance? They held air fine all summer.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • netcsk
    • Apr 2004
    • 1609
    It's usually a nail. Take it anywhere that does tire work and they'll find the problem for you.
    • Joe318is
      • Sep 2005
      • 6451
      Check bead leaks also, take soapy water and spray the entire tire down, look for a leak.
      Even the core of the valve stem could cause it.
      Originally posted by vlad
      • JGood
        • Jan 2004
        • 7959
        I checked for nails. I use the tires for track days, they definitely get inspected after every session...
        I don't think it's leaking fast enough for the bubble trick to work, like I said, 2-3 psi per day.
        I'll just have it remounted and put in a new valve stem.
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          "Bubble" trick always works, you just have to take it to a shop with a full submurge tank and hold it under the water level. once the waves stop even a 1 psi leak will show.
          • JGood
            • Jan 2004
            • 7959
            Well I can submerge the tire in water. I'll just chop a 55 gal drum in half. I just didn't think I would see bubbles from a leak that slow. But I guess the air has to come out somehow...
