BBS Garage: All things BBS
This is a sticky topic.
  • E30 Wagen
    • Jul 2005
    • 3434
    #631
    how polish/restore my BBS wheels?
    Just picked up these RZs and I want to make them look like new again. How should I go about polishing the lips and addressing some of the areas pictured? I've never polished wheels before and I don't want to buy a product or do anything stupid that will damage them.
    My Feedback
    • kreasims
      • Jan 2009
      • 149
      #632
      You have to get rid the clear coat to clean those worm. After the coat gone, you'll need to wet sand it until its gone. Then you'll need to polish it with metal polish to make it shine. Those curb rashed can be fixed easily by manual grinder.
      There are lots of detailed information of refinishing your wheels on the web. Good luck.
      • Eric
        • 5142
        #633
        Found these today while looking through some old pictures. I drooled over them the day I saw them, and here I am drooling over them again!
        BBS E30
        DSCN0224 by ericandshovin, on Flickr
        DSCN0223 by ericandshovin, on Flickr
        DSCN0222 by ericandshovin, on Flickr
        DSCN0221 by ericandshovin, on Flickr
        DSCN0220 by ericandshovin, on Flickr
        • DTM190
          • Nov 2008
          • 1107
          #634
          So old school it hurts. I remember the first time I saw some here, its what got me hooked on multi piece rims
          Originally posted by der affe
          first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
          if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
          • 416stroker
            • May 2008
            • 2448
            #635
            How hard is it to source 16"BBS RZ323 caps ? I can find any that look close to my other on ebay. Can find them ON .de though. But dont know if I want to go threw the hassle.
            84 318I Delphin RIP
            87 325IS delphin 24v Sold
            89 325 Alpineweiss
            • hexagone
              • 1277
              #636
              Large waffle + twist lock hex nut from RF/RG/RZ
              See picture below. You need the two black plastic twist locks on the outside- NOT the center one. That is from 14" basketweaves.
              • mooseheadm5
                • Apr 2009
                • 375
                #637
                Some RZ caps lock differently than the ones on the RZ323. You need BBS RG caps. They lock into the center of the hub. They are the same caps as E28 M5 and euroweave. I'm pretty sure that you need the one in the center of the picture that hexagone posted, not the ones at the left and right.
                You can still get E28 M5 caps new from BMW.
                -P
                Moosehead Engineering
                • hexagone
                  • 1277
                  #638
                  I'm positive it's the outside ones.
                  RG caps also use the outside twist locks. In fact, I spent a considerable amount of time with one of the members on here looking into this matter- I just forgot his name. He has the black m-tech sedan with the blue m tech interior and RGs, and is from CA. He's got RGs too and can confirm.
                  • mooseheadm5
                    • Apr 2009
                    • 375
                    #639
                    Does the center hub of the wheel look like this?
                    That should be the wheel he is talking about.
                    -P
                    • hexagone
                      • 1277
                      #640
                      • mooseheadm5
                        • Apr 2009
                        • 375
                        #641
                        The biggest problem with BBS RZ wheels is that they different RZ models have different center caps. The one like I posted needs the center lock twist cap, but if it has a groove cut around the raised hub portion, it takes the cap that hexagone shows. If you can post a picture of the center of the wheel then you can get a definitive answer.
                        -P
                        • 416stroker
                          • May 2008
                          • 2448
                          #642
                          Originally posted by hexagone
                          That cap is wrong. Mines like the center one in your previous post
                          84 318I Delphin RIP
                          89 325 Alpineweiss
                          • 416stroker
                            • May 2008
                            • 2448
                            #643
                            That is the center
                            84 318I Delphin RIP
                            89 325 Alpineweiss
                            • mooseheadm5
                              • Apr 2009
                              • 375
                              #644
                              You can buy E28 M5 caps from the dealer then, but they cost about $60 each.
                              -P
                              • 416stroker
                                • May 2008
                                • 2448
                                #645
                                OK I thought so and IX caps are the same to right? real oem gives the same PN
                                84 318I Delphin RIP
                                89 325 Alpineweiss
