Headliner Repair
  • KingDaKa
    • Jul 2016
    • 8
    Headliner Repair
    Has anyone had the headliner repaired on their touring? I've had a few searches and haven't come across any DIY links or build posts on it being done. It seems to be a fabric glued onto a board but any information would be great.
    1990 320i RHD Touring (slow project)
    1988 1JZ-GTE Shaved/Wire tucked Coupe (old project-scrapped and stripped)
    2004 Subaru Forester XT
  • cory58
    • 1021
    There is an awesome DIY at e30owners.com. It's called "how to remove touring headliner".
    Yes - it is a rigid board (unlike other E30s).
    1992 325i Cabrio
    1988 320i Touring
    2000 M5
    1977 530i
    2015 328i - Euro Delivery/Performance Center Delivery
    BMWCCA
    E30CCA
    • KingDaKa
      • Jul 2016
      • 8
      Thanks man you're a life saver. The wagons seems a hell of a lot easier to repair than the other models. I may just knock mine out sooner than I thought.
      • cory58
        • 1021
        Cool! Create a thread here with some pics and anything you learn from the process. I'll be recovering my disgusting headliner eventually.
        Cory
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        BMWCCA
        E30CCA
        • RHDE30Touring
          • Feb 2016
          • 59
          Just took mine out. Super easy, all you gotta do is remove everything on the headliner, (oh shit handles, dome lights, everything) then take the pillars down to the second clip or so, exposing the headliner. Then, just pull. Sunroof is a bit of a pita. Make sure it is open before you start the process as there are some screws that you have to take out.
          Good luck.
          • 808e30325i
            • 537
            Did mine with alcantara about 4 months ago, piece of cake!
            • doba_s
              • Jul 2014
              • 29
              any suggestions where to get factory like material to rewrap the headliner?
              16 GT3RS
              16 GT4
              05 M3
              88 M3
              90 Mtech Touring
              89 Touring
              91 325i
              • Roadrunner
                • Mar 2016
                • 221
                I haven't had to redo the headliner on my touring (the previous owner had it reupholstered by a custom auto trim shop), but Proctor750 shared some info on my project thread that might be helpful:
                Originally posted by Proctor750
                as for headliner i used opal gray winchester 1/8" foam backed 4 yards. I believe it is called world uupholstery or some such place. Excellent match.
                adhesive was dap weldwood high temp spray adhesive.
                1994 E30 316i Design Edition Touring / 1991 E30 318is / 1992 E34 M5
                Instagram: @ro4d_runn3r
                • ZM Blue Devil
                  • Dec 2006
                  • 13836
                  Just had mine done what a difference!
                  Levent
                  %20levent@gutenparts.com
                  Ladies:
                  • Garage30
                    • Aug 2015
                    • 123
                    I have done a bunch of touring headliners. Used to do them with alcantara but these day I use alcantara with stretch in it. Looks 95% as good and is so much easier to work with.
                    Euro car and parts export business based in the Netherlands, specialized in E30 Tourings!
                    Instagram: @garage30_ WWW.GARAGE30.NL
                    • janice212
                      • Oct 2016
                      • 17
                      Need to do mine also. More than happy to see some pics of this project :D
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Finished the one for the non-sunroof 318i last week. Got the material (flat knit in oak, which is slightly too dark, but only slightly) from yourautotrim. Can't say I was happy with the adhesive used, so do your own research there.
                        Beyond the obvious A-D pillar covers, lights and weather stripping there are 8 clips that hold the liner in place, 4 in the center that slide straight back to release and 4 at the very rear that should pull down for removal. If it's not clear, do the rears first.
                        Then it's only a matter of cleaning up the headliner card (wire brushes worked great), installing the fabric, and reinstalling the assy. Be very careful reinstalling the slide clips as they will break if they are torqued over.
                        The whole process took under 3 hours, just under $100 with the adhesive, and is well within the ability of anyone that can turn a wrench.
                        • Shangsta
                          • 1485
                          I am going to need to redo this on mine. Thanks for the link earlier in the thread. This should be a whole lot easier than the one in my coupe
                          :shock:
                          • cbouchez
                            • May 2007
                            • 2789
                            My headliner it's in great shape - I'm having issues with my sunroof and no one wants to touch it because of the lack of experience with he headliner on this vehicle.
                            Follow my IG @bouchezphotography
                            • 808e30325i
                              • 537
                              It's the easiest headliner to do of all the e30's.
