My e34 came with airbag steering wheel, purchased another steering wheel non airbag type which was designed for the e34 /e30 but when I pulled off the airbag found the spindle shaft was thciker and different splines so it didn't fit.
I was(I'm still) looking for a parted out e34 to buy the steering column to retrofit it completly in my car (non airbag) but can't find any. After looking through REALOEM is not clear enough the notes each different P/N for the spindle shaft for what type were made.
I ended up purchasing this shaft alone 32 31 1 156 068
Sure enough I would need the flange and all the clips/washer/springs etc to adapt it, but at this point I'm unsure if it will actually fit in the original column.
I think some people has done this swap but I can't find the detailed parts involved in this change.
Any clues?
Thanks
Any clues?
Thanks
