this is nice...
So i have a 1995 540i/6. I just recently replaced the drive door lock actuator as it was not working (had to lock the doors manually from driver side everytime). once i fixed that i replaced the batteries in the keyless remote (3 button integrated into the key) and re configured the remote to work.
So now all of that works, the problem is about 1 minute (maybe less) after you lock the car with the keyless remote the alarm will start to go off.
Any suggestions? I have already unhooked the hood sensor and that did nothing different. I have also hit the lock button 3 times which should disable the tilt sensor (is there any special alert the car gives when this works?) and no difference.
