E28 Coilover suspension DIY (in progress)
  • tcturbo91
    • 94
    #46
    I am looking into doing some coilovers in the next few months for about 8-900. I would love to do ground controls, but I am a poor college student.
    I was looking into piecing a kit together, whether it be GC or IE adjusters, a shorter shock (I have heard G60 VW Shocks work, not totally confirmed yet), and some fabrication. I then started looking into it a bit more, and Nex actually makes a kit for the E28. I knew they made coils for the E34, but now I have been seeing more and more for the E28. They are $799 shipped on ebay. I think this is the route I may go, as for what I need, they are good enough
    • downernsp
      • Mar 2008
      • 1932
      #47
      @iamcreepingdeath I am aware of the rear hence my question. I was not sure some knew. As for brakes from e34 they fit for those whom are wondering rears tho and use e32 750 in front and you have ur.self a bbk.
      Sent from my SGH-T959 using Tapatalk
      • iamsam
        • Jun 2008
        • 176
        #48
        Trying to decipher your last sentence. Does E34 540i suspension bolt up to an E28? front AND rear? Why E32 750? just bigger brakes than the E34 540?
        • slammin.e28
          שמע ישראל
          • 12054
          #49
          No
          Master cyl bolts on, bigger. Brakes, IIRC are bigger, but really, e34 brakes are more than enough, especially with a 750 MC. Do some SS brake lines while you're in there and make sure you tape your face on before touching that brake pedal.
          • iamsam
            • Jun 2008
            • 176
            #50
            What about a 540i suspension does not work? I heard that it does on myE28...
            • slammin.e28
              שמע ישראל
              • 12054
              #51
              http://www.mye28.com/viewtopic.php?t...e34+suspension
              Last page:
              • iamsam
                • Jun 2008
                • 176
                #52
                Interesting. Still, no specifics on what DOES and DOESN'T fit in detail, since I hear that E34 540i brakes bolt up...
                • slammin.e28
                  שמע ישראל
                  • 12054
                  #53
                  Brakes bolt up. That's about all I'd worry about from a e34. I see no advantage in swapping anything else e34 -> e28 except a B35 swap or a M1.3 upgrade.
                  As far as suspension, SPAX. That is all.
                  • iamsam
                    • Jun 2008
                    • 176
                    #54
                    Well the whole reason I started this thread is to finsd a cheaper DIY option for a coilover setup for an E28, and that is what I want to stick with, for the height adjustment and the quick spring rate interchangeability.
                    • iamsam
                      • Jun 2008
                      • 176
                      #55
                      Found this on myE28, apparently you can get the entire E34 front suspension to work on an E28. http://www.mye28.com/viewtopic.php?t=78698&
                      • downernsp
                        • Mar 2008
                        • 1932
                        #56
                        My bad ok e34 rear brakes with front e32 brakes makes a big brake kit on e28. I have that set up on mine e28. For a plus also add like slammin.e28guy said MC from 750 to complete a nice brake system.
                        • iamsam
                          • Jun 2008
                          • 176
                          #57
                          So E34 front brakes don't work on an E28?????
                          So much conflicting info... I am just going to find out for myself. I have an E28 and an E34 540i parts car...
                          • latinobimmer
                            • 226
                            #58
                            They do work, dude. It's just that the E32 750iL front brakes are "better" than the E34 ones, in that they are bigger.
                            • iamsam
                              • Jun 2008
                              • 176
                              #59
                              I see I see
                              • AsharC
                                • Jun 2011
                                • 1508
                                #60
                                Just find 8 series brakes, they fit. My car has em, the PO put them on.
                                BUY MY WHEELS! BBS E50s!!
                                http://www.r3vlimited.com/board/showthread.php?t=275407
                                Originally posted by Lurker27
                                Any man will tell you being blown is better than being stroked.
