E28 Coilover suspension DIY (in progress)
  • AutoXinE30
    • Aug 2007
    • 277
    #76
    Originally posted by iamcreepingdeath
    So that's good! That means you can shorten the E28 strut housings for coilovers w/ E30 shocks.
    That is good news. Officially any option for an E30 will work for an E28.
    For a ~1 in shorter housing use standard E30 shock inserts.
    For a ~2-4in shorter housing use E30 IX shock inserts
    For a ~5 in shorter housing use G60 shock inserts (Probably more then anyone would really need.
    Now we need an easy to find rear shock option that is a little shorter then E28 shocks....
    • iamsam
      • Jun 2008
      • 176
      #77
      yes. Good info. Find some rear shocks, and I'll have some on order very soon. My E28 needs some coilovers.
      • AutoXinE30
        • Aug 2007
        • 277
        #78
        Well most E28's seem to range between 3000-3300lbs depending on who weighs 'em... I've seen between a 54/46 and a 52/48 weight distribution so, that makes ~690-792lbs on each rear shock.
        You happen to know the overall length of the rear E28 or rear E34 shock? The rear E34 is supposed to be about an inch longer.
        I would imagine if someone had an E28 or E34 shock we might be able to e-mail Koni with the dimensions they may be able to find something for us? I'd do it if I had a rear shock off the car.
        • einstein57
          • Jun 2007
          • 10780
          #79
          Playing around with different setups. 6" 450f spring and 8" 375r spring. Front is all the way down on billie sports. Rear can go another 2" lower but i need to roll the fenders first. 16x8 et11 enkie ek 96s
          www.gecoils.com
          • iamsam
            • Jun 2008
            • 176
            #80
            ^^ spill the beans man!! what shocks did you use (as in what model), did you shorten the front strut housings, and how does it ride on billy sports?
            • einstein57
              • Jun 2007
              • 10780
              #81
              Standard e28 sport struts. It was a little to bouncy so I raised it up an inch and its much better. I figure camber plates and a cut bump stop will give me the same ride at the lower stance. If not I have tons of spare e30 billie sports. Like 3 sets lol.
              www.gecoils.com
              • iamsam
                • Jun 2008
                • 176
                #82
                whoa I think I know some people who really want billy sports....
                • einstein57
                  • Jun 2007
                  • 10780
                  #83
                  I'll probably package them with coilovers and strut tubes so people can have a thrifty bolt in complete coilover system.
                  www.gecoils.com
                  • AsharC
                    • Jun 2011
                    • 1508
                    #84
                    ^^What coilovers are you using?
                    BUY MY WHEELS! BBS E50s!!
                    http://www.r3vlimited.com/board/showthread.php?t=275407
                    Originally posted by Lurker27
                    Any man will tell you being blown is better than being stroked.
                    • einstein57
                      • Jun 2007
                      • 10780
                      #85
                      German Engineering of course.
                      www.gecoils.com
                      • AsharC
                        • Jun 2011
                        • 1508
                        #86
                        How much would these cost a young fellow?
                        • iamsam
                          • Jun 2008
                          • 176
                          #87
                          I would say a fellow may benefit in following the link in his signature, namely, www.german-engineering.net, but hey, I dunno. That said, I haven't clicked yet.
                          • AsharC
                            • Jun 2011
                            • 1508
                            #88
                            I checked before I posted. I know how pissed r3v gets when you don't do simple shit.
                            • iamsam
                              • Jun 2008
                              • 176
                              #89
                              ha ha yeah I didn't even check...
                              • einstein57
                                • Jun 2007
                                • 10780
                                #90
                                Price will be about $365 for the e28 coilovers. I'm changing the sleeve to a different style for better fitment. The front sleeves on my car and AJs are "Shrink to Fit" and are a pain to install on a cold day. The aluminum cools and shrinks too fast. Going with an easier to install sleeve that will be part of my "Black Line" kits. I should have 3 kits in stock after bimmerfest
                                www.gecoils.com
