E28 Coilover suspension DIY (in progress)
  • BavarianAddict06
    • Sep 2011
    • 315
    #106
    Originally posted by einstein57
    Diesels not ready. Too hot to roll the fenders. I have to now with the wider rubber. Sneak peak
    6 months. The biggest thing is determining spring rates since most people have no clue what to get or if they will blow out their shocks. Also their is the potential hazard of people not relocating the spring perch clips correctly which could make them pop off and completely dumping the rear of the car.
    god damn it nigel. those wheels are freakin awesome dude!!!!!! props! hope to see u sunday! bring the e39
    1987 528i Royalblau
    • iamsam
      • Jun 2008
      • 176
      #107
      Originally posted by darksideracer69
      There's a lot of info around for the e28 mods. Someone needs to compile a info thread.
      That's why I made this thread.
      • cheapshot
        • 451
        #108
        Did anyone ever figure out if there was an alternate rear shock option. Something like the camaro shock for the e30?
        • AsharC
          • Jun 2011
          • 1508
          #109
          Idk if its been covered, but BC Racing made coilovers for the e28. I'm selling my style 5's to buy them :)
          BUY MY WHEELS! BBS E50s!!
          http://www.r3vlimited.com/board/showthread.php?t=275407
          Originally posted by Lurker27
          Any man will tell you being blown is better than being stroked.
          • slammin.e28
            שמע ישראל
            • 12054
            #110
            All I know of is the 914 rear shock. Donno what kind of modification you have to do, but I know a guy running them on his track car.
            • cheapshot
              • 451
              #111
              So here is what I did to my e28 based 6er. Gleaned knowledge from here and other sites and thought I would share. I have since found out from Slammin that 914 shocks will work in the rear but I cannot speak to that myself. I wound up with about $200 in my setup that you see here and it rides AMAZING!! I can still go 3/4" lower in the rear but that renders it "undriveable" due to the exhaust scraping. I have a set of used billy struts that I am going to send off to get rebuilt for the front but I got to tell you that the KYB's are more than adequate. She really does ride and handle VERY well.
              Parts List
              Slightly used e30 KYB GR-2 strut insers. $30
              Slightly used Billy sport rear Shocks $125
              Universal Coil kit. 385lb front, 315 rear, 6" springs, 2.5 ID (Free to me) $60 for arguments sake.
              Misc nuts because I bought used. $4
              Grand total- $199
              Section approximately 3/4" out of your stock strut housing below the spring perch.
              Cut off the majority of the spring perch, leaving the lower 1/4" or 1/2" for a collar for the sleeves.
              Use a flapper wheel on a grinder to clearance the top of the strut so the sleeve fits tight. It will want to go onto it without this but it hangs up. I would not recommend using a grinder wheel as you may wind up taking to much off.
              Toss the stock top hats and use the ones in your universal kit.
              Set your rear spring perches on the billys to their lowest level, put the sleeve over the shock body. Then install the spring and top hat.
              Viola'.
              This is what you get.
              • iamsam
                • Jun 2008
                • 176
                #112
                ^^^ nice!!! So what universal spring kit did you use?
                • 5Toes
                  • 9836
                  #113
                  Need e34 coilovers Nigel!!!
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    #114
                    Ebay breh. "Honda coilover kit"
                    • iamsam
                      • Jun 2008
                      • 176
                      #115
                      ha ha serious? So all you need is 2.5" ID 6" long springs?
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #116
                        BAM! Pick one...
                        http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                        Not sure how they'd fare as a track coilover, but for looks, they def do the job. I may give them a whirl when I get around to redoing my e28's suspension, but it's more of a trackable-driver. Figure that if the rates are good, they should hold up fine.
                        • iamsam
                          • Jun 2008
                          • 176
                          #117
                          BAM! Pick one...
                          How do you tell what the spring dimensions are from any of those ads? They don't seem to list it.
                          • cheapshot
                            • 451
                            #118
                            Dead serious. The ones I used on my e24 were listed for a 240sx but they are all the same damn thing. I just received my kit for my e21 from a civic. They are all 2.5" id 6" length that I have seen. I will try and test the spring rates on them today. The spring rates are great for a daily driver/canyon carver. If you want to track the car, I would invest in some higher rate springs. The collars and sleeves will work just fine for a track car. We also just did this to my buddies e30 and it is one of the best if not the best riding lowered cars I have ever been in. Only difference is we used g60 struts and camaro kyb gas adjust rear shocks. It's effin ridiculous how good the thing rides and handles.
                            • cheapshot
                              • 451
                              #119
                              You can also piece this together from afco but you will spend 3x the money.
                              • iamsam
                                • Jun 2008
                                • 176
                                #120
                                Hmm this is very very good info. So I assume the ebay honda coilover sleeves fit fine on the E28 strut bodies?
                                Also, do you have pics of the process?
