Here is a DIY on myE28 on installing coilovers. http://www.mye28.com/viewtopic.php?t=45048&
However, I still have several questions, and also I would like to compile as much coilover conversion DIY material into this post as I can that may be floating around the internet in various locations. My main goal is to have a comprehensive DIY for building your own coilovers from a set of springs and hats, and appropriate shocks.
Front shock insert options:
Standard E30 inserts are about an inch shorter than E28 inserts, but otherwise the same. E30 iX inserts are shorter still. Good options are Konis or revalved Bilstiens for the front, or Spax E28 specific shocks if you don't need to shorten the housing.
Rear shock options:
It seems that Koni rears are NLA, but I hear that Spax shocks are a great. More on this when I actually get my new Spax shocks installed.
Spring options:
Obviously GC makes the springs/hats/adjusters you need for $400.
You can also use cheap ebay 240SX springs for $45 (with hats and adjusters included), as they are 2.5" ID and 6" length, and I hear they work well (from username cheapshot, see posts following). Not sure on the rates however, but for $45, the worst that can happen is that you are out $45 and have some extra springs and hats/adjusters to fiddle with. (Just search "240SX coilover" on Ebay Motors)
Summit Racing also sells Eibach springs to the spec you need (2.5" ID and whatever length/rate you like) for $60/spring, amounting to $240 for a set of four, much cheaper than CG, but no hats/adjusters of course.
Examples:
Front: http://www.summitracing.com/parts/ei...0450/overview/
Rear: http://www.summitracing.com/parts/ei...0350/overview/
Rear shock options:
Spring options:
Examples:
