Knocking sound from middle of car...
  • be34st
    • 1277
    I went to check out a 535i/5 that im thinking about buying but like the title said it's making a funny noise.
    It's a fairly loud knocking sound upon acceleration and goes away almost as soon as you exceed 5-10 miles an hour. I dont know much about the drivetrains on these cars but I;m thinking a bad guibo, or differential?
    Other than that the car is cherry.
    What could be making this noise?
    07 Designio E63 AMG / 1984 318i (M20Swapped)
  • red_e30
    • Dec 2010
    • 242
    sounds to be carrier bearing on the drive shaft might not be the bearing itself but the rubber is ripped that holds it
    my build thread:http://www.r3vlimited.com/board/showthread.php?t=232324
      • 37829
      Yup, csb is the most likely cause. May need a guibo as well.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • KenC
        King of Kegstands
        • 14396
        Probably needs a new driveshaft, CSB, and flex disk.
        Originally posted by Gruelius
        • be34st
          • 1277
          Is that a costly/difficult repair? Or is it something I can knock out with some jackstands, a few tools, and a few hours?
          • DrLeadFoot
            • Aug 2011
            • 461
            CSB for sure. Replace the guibo while you're in there. Mark your drive shaft before you pull it apart. And check the u-joints.
            Then drive
            Instagram: @DrLeadFoot
            • John in VA
              • Aug 2007
              • 553
              If it is, indeed, the center support bearing rubber, you might consider replacing the guibo/flex disc and tranny mount "while you're in there." Stress on one area leads to stress on the others.
              Check the universal joints on the driveshaft, as binding can cause problems. If they're bad consider a replacement from http://www.driveshafts.com/, or if you have a buddy at a repair shop go for http://www.beyerdriveline.com/mission.html
              • be34st
                • 1277
                Thanks guys. I think i'm gonna go ahead and pick this one up. It's just too clean to pass up for the price.
                • BavarianAddict06
                  • Sep 2011
                  • 315
                  Check the center support bearing. happened to my car. Its an easy fix :)
                  1987 528i Royalblau
                  • BavarianAddict06
                    • Sep 2011
                    • 315
                    Its 20 bucks or something. pelican or bma
                    1987 528i Royalblau
                    • smooth
                      • Apr 2005
                      • 1940
                      There's a shop local to you that will rebuild it for $150 or maybe it was less it's been a couple years since I had mine done. You can spend $20 here and there fixing the guibo and CSB but make sure your ujoints aren't clunky because if they are you'll end up wasting money doing the rebuild anyway.
                      I replaced my guibo and CSB and then a year or two afterwards when I replaced my diff I noticed my ujoints were blown so I ended up having the whole driveshaft redone. I think the whole thing took three days max.
                      If you don't want to do the work yourself call Robert at e30motorwerks or Richard at Michaelangelos. Robert is further from you (HB) but more laid back. Richard is more of a drop the keys off and gtfo his way type of guy. He's over in Lake Forest.
                      Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                      • be34st
                        • 1277
                        Thanks guys.
                        I've ordered the CSB, so it should be here by the weekend. I usually take my cars to Pure Performance in Lake Forest. Daniel is a cool guy to work with. I haven't decided if this is something I want to tackle my self but I'm pretty mechanically inclined so it shouldn't be too much to handle.
                        • smooth
                          • Apr 2005
                          • 1940
                          It's routine but the u-joints are not serviceable so if they're bad you have to send it in or get a replacement driveshaft.
                          • be34st
                            • 1277
                            I hope that's not the case.
                            • xxx-Lost-Soul-xxx
                              • Apr 2008
                              • 1953
                              I hope you didnt get a Uroparts CSB. Pure CrapOLA.
