4.4 into e34??
  • bimmer630
    • 1228
    4.4 into e34??
    Is it possible to directly replace a 3 liter V 8? with a 4.4 non vanos? Vehicle in question is a 95 530 I
  • goarmy
    • Nov 2011
    • 622
    Put the question in hand to the V8 section of the forrum.
    • slammin.e28
      שמע ישראל
      • 12054
      Yes.
      4.0 is a direct swap, just swap the ecu.
      Don't see why running a 4.4 on OBD1 would be that much more difficult.
      • Vtec?lol
        • Dec 2009
        • 3278
        if you change over the timing chain and covers it'll run off the factory DME I believe. I think you'll need to use the heads off you 3.0 as well
        • iamsam
          • Jun 2008
          • 174
          Are M60B30 and M60B40 heads the same?
          • Jean
            • 18228
            the m60 4.0 is basically plug and play, but 4.4 isn't.
            You'll need to convert the m62 4.4 to obd1 to run in the e34, or make a hybrid m62 using parts from the 4.0 m60.
            3.0 m60 intake/throttle/heads/valves are different from the 4.0
            3.0 and 4.0 share the same oil pans/timing covers upper and lower, but the internals are not the same, cams are though.
            example -
            3.0 cams on the 3.0 and 4.0
            11311736117 on the 4.0 = 11311736117
            11311736131 on the 4.0 = 11311736131
            11311736119 on the 4.0 11311736119
            11311736133 on the 4.0 11311736133
            intake valve 32,0/5.94 11341435476 on the 4.0 35/5.94mm 11341435480
            exhaust valve 28.5/5.94 11341435478 on the 4.0 30.5/5.94 11341435482
            lower timing cover 11141733522 / on the 4.0 = 11141733522
            upper covers 11141729583 / 11141729585 / on the 4.0 11141729583 / 11141729585
            head 11121731912 / 11121731913 on the 4.0 = 11121731910 / 11121731911
            Obviously 4.4 cams are totally different as well, along with the heads too.
