E34 Touring (M50) Won't Start
  • ClayW
    • Apr 2011
    • 377
    This is a friend's 1994 E34 Touring. I've changed the fuel filter for him, but to no avail. This is what happens when we try to start it:
    Any ideas? Fuel pump? Fuel pressure regulator?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • e30austin
    • 15382
    Sounds like a classic case of "cranked it too many times with a weak battery" or something of the like. Seems like it has low compression.
    I would pull all plugs, clean them well with carb or brake cleaner, dump a little bit of oil down each spark plug hole, reinstall plugs and try again. When it fires, it will want to die...do not let it die, it will be a pain in the ass to restart.
    '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
    • ClayW
      • Apr 2011
      • 377
      What will that procedure accomplish?
      If it's low compression, are we talking about a head gasket? Rings?
      • e30austin
        • 15382
        When you're cranking the motor with a weak battery (or whatever the case may be) for extended periods of time, the oil is getting washed off the rings and it causes a no start condition due to loss of compression. Dropping oil down the cylinders will get the oil back on the rings and build up compression again.
        I've had this happen on a couple cars and have tried this little trick and it worked fantastic.
        • ClayW
          • Apr 2011
          • 377
          Thanks! Will try.
          What might have caused the no start condition to begin with?
          • e30austin
            • 15382
            A weak battery (due to cold weather or other factors) is your likely culprit.
