m30 heads
  • JJe30
    • 2044
    m30 heads
    Are the late model e28 and e34 m30 heads the same? Found a rebuilt 88 535i ( e28 ) head and I have a 90 535i. Wouldn't mind picking up this head if it would swap directly on. Thanks
  • slammin.e28
    שמע ישראל
    • 12054
    No. It will go on, but it is inferior to the B35 head in almost every way.
    Smaller ports, valves, less aggressive cam, etc, etc.
    • JJe30
      • 2044
      Ah, ok. Thanks for the reply
      • South26
        • Jun 2011
        • 856
        Sorry that is wrong, in fact it will give you higher compression.
        Andy
        • slammin.e28
          שמע ישראל
          • 12054
          In fact it is not. Yes you will get higher compression, but the head will require so much work to make it comparable to a B35 head. Valves are smaller, cam is less aggressive, ports are smaller, etc.
          OP states, "swap directly on". The answer is yes, but it will be detrimental to the performance of the car without heavy modification.
          • F34R
            sLaughter
            • 12385
            1+ on all of that, local buddy has a b35 bottom end with a b34 head. Think of it like this: b25 bottom end with a b27 head.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
