E34 540i mystery wire
  • Gaode
    • Mar 2013
    • 48
    Hey everyone, I've been trying to figure out where this connector goes for a while. But I can't find where it plugs into. Anyone know?
    1995 540i 6spd
  • straight6pwr
    • Sep 2004
    • 3450
    the wires that come out of that side of the harness go to:
    crankshaft position sensor
    throttle body position sensor (there is the main one and the ACS one)
    idle control valve
    oil pressure sensor (i think)
    maf (its not the maf, different plug)
    • Gaode
      • Mar 2013
      • 48
      idle control valve
      Thank you! I will double check all of them right now
      • Gaode
        • Mar 2013
        • 48
        Hey correct me if I'm wrong, but is this the oil pressure sensor?
        • straight6pwr
          • Sep 2004
          • 3450
          yeah that should be the oil sensor.
          • Gaode
            • Mar 2013
            • 48
            Yes.. Already have something plugged in there...still have that mystery wire
            • marshallnoise
              • Sep 2013
              • 3148
              If your car is a manual transmission, then that is an additional sensor for the throttle body that is only used on automatic transmission cars. They used one harness for all the V8 cars.
              Si vis pacem, para bellum.
              New Hawtness: 1995 540i/6 Claptrap
              Defunct too: Cirrusblau m30 Project
              Defunct (sold): Alta Vista
              79 Bronco SHTF Build
              • straight6pwr
                • Sep 2004
                • 3450
                i'm not sure about this, all throttle bodies are the same, manual or automatic. what other sensor would there be?
                OP, willing to cut the shrink wrap away to learn the wire colors?
                • marshallnoise
                  • Sep 2013
                  • 3148
                  I am pretty sure it is what I translate as "starter." It must have some other meaning in German but your guess is as good as mine.
                  • marshallnoise
                    • Sep 2013
                    • 3148
                    Its the ASC+T plug. Gaode, does your car have an ASC+T button to the left of the shifter?
                    And there are two throttle bodies apparently. http://www.bimmerforums.com/forum/sh...of-this-wiring
                    EDIT: The reason why most people have no idea what the plug is, is that it looks like only the 540i/6 M-Sport cars had the feature. A lot of the automatic cars had the feature and many of the 525s had them as well.
                    • jpod999
                      • Dec 2015
                      • 1401
                      So if the car doesn't have the ASC+T the connector just sits there unused?
                      OBDI M62B44/6 swap
                      Transaction feedback
                      - jpod999
                      • marshallnoise
                        • Sep 2013
                        • 3148
                        Sure. If you were BMW, would you make two different harnesses for the omission of one option item?
                        • Gaode
                          • Mar 2013
                          • 48
                          Yes my 540i is a 6spd. And I've spent so much time looking for a spot to plug it in.
                          I will pull the shrink wrap back a little and inspect the wires.
                          And I'll also check for the buttons next to my shifter.
                          I'm just worried about when I go to smog/emissions test because it can cause a failure for visual. (Missing pieces from the engine etc.)
                          • jpod999
                            • Dec 2015
                            • 1401
                            Been doing some more reading on this...isn't this where the ASC+T connector goes? If so, it looks like it's already connected or am I just seeing it wrong?
                            OBDI M62B44/6 swap
                            - jpod999
                            • marshallnoise
                              • Sep 2013
                              • 3148
                              That does look like it and it does look like it is plugged in already...Interesting.
                              FYI, here is my throttle body. Much different looking than the OPs. I bet the short one that is unplugged in the pic below is the ASC+T. In which case, the OP and I have the same loose wire. Can you tell what colors mine are?
                              Another look at my throttle body. Only has one throttle body blade.
