Fuel pump\s
  • Kavadarci
    • May 2021
    • 59
    Fuel pump\s
    Hi
    while driving my car without the back seats to troubleshoot roof noises I noticed what I believe it’s a fuel pump noise that is not as noticeable with the seats on.
    the sound is pronounced and now that I don’t have sounds from the roof I can hear it well.
    My question is if this is normal and how many fuel pumps do I have?
    rockauto has fuel pump inside the tank and outside of the car. I don’t think I have one outside.
    also should I replace fuel sending unit and where is that located?
    thank you
  • Vincenze
    • Apr 2019
    • 1028
    There are rubber sleeves for fuel pumps.
    The problem is the sending unit is inserted near the pump and may not provide enough clearance for a sleeve.
    If you're there, can you measure the diameter of the pump and the distance between it and the sending unit.
    I believe the diameter is close to 36 mm.
    Maybe, something like this will work.
    https://www.highflowfuel.com/quantum...RoC9K0QAvD_BwE
    • 82eye
      • Jan 2009
      • 2061
      Originally posted by Kavadarci
      Hi
      thank you
      fuel pump runs constant. they buzz like mad if gong out but will continue on for a while until it starts driving issues. could also be you just notice it more without the sound dampening from the rear seat.
      my e30 has 2 pumps. a sending unit / lift pump in the tank and a fuel pump by the passenger rear tire.
      • Kavadarci
        • May 2021
        • 59
        Ok I’ll check for both
