Testing cooling system
  • hp13
    • Sep 2021
    • 39
    I’m working on an M30 swap and I’ve got the cooling system all set up. Is there any way to check if the coolant is circulating and the engine is being cooled without letting my engine run for too long and potentially overheat? The temperature gauge is not moving so that could be because I wired it in incorrectly, the sensor is bad, or the engine is just not getting any coolant. I let the car run for a couple minutes and the hose connecting to thermostat to the water pump was warm but everything else stayed the same temp.
    I also have the E34 overflow tank set up by the firewall if that helps.
  • e30davie
    • Apr 2016
    • 1788
    Did you bleed all the air out?
    • hp13
      • Sep 2021
      • 39
      I believe I did bleed all the air out as when I open the bleed screw a stream of coolant comes out with no air bubbles. I haven't tried lifting the front of my car up and bleeding it yet which I might try next.
      • Panici
        • Dec 2009
        • 2520
        You'll have to run it up to temperature enough for the thermostat to open up.
        The rad should stay cold until that happens.
        • hp13
          • Sep 2021
          • 39
          Can I test the radiator temp with an infrared thermometer or is there a better way?
