Wiseco m20b25 Pistons Problem
  • panose30
    • Nov 2009
    • 105
    Hi I need some help for my forged m20b25 bottom end.
    I have the Wiseco pistons with part number KE317M845AP
    which they have 34.7 compression height,im using 135mm rods,stock crankshaft,84.5 mm bore. 75 stroke
    My issue is that those pistons hit on my 885 head with oem standard head and with oem oversize headgasket.
    Keep in mind that my engine was in perfect condition and i just wanted to build a forged block to be able to run a turbo,so i just bore the block ,Head was in perfect condition
    Wiseco on their site claims that those pistons are for 206.7 deck height.
    I made some maths and i have this result
    75/2+135+34.7 =207.2 which is 0.5 more than the oem specs.
    If i use the oem compression height piston which is 34.2 the result is 206.7 which is correct
    Did i miss something? Are those numbers from Wiseco correct?
    If i want to run this engine i will need at least 2.5mm Mls headgasket?
    Thanks and sorry for that big post
  • digger
    • Nov 2005
    • 6194
    What does top of piston look like?
    • panose30
      • Nov 2009
      • 105
      Like oem pistons for 885 head
      • digger
        • Nov 2005
        • 6194
        Thicker gasket will do it, can add some shims and check with clay to work out the best thickness
        • panose30
          • Nov 2009
          • 105
          We try the oversize 2.05 and it dosnt work,
          The Wiseco has the m20b25 block height 206.7 and the compression piston height 34.7 ,also it says deck clearance 0.5
          So we that numbers how much sits the Wiseco over the block ?
          1mm or 1.5mm?
          • digger
            • Nov 2005
            • 6194
            1mm or 1.5mm?
            You would need a mls as these are available thicker than oe gasket.
            you need to know your deck height it will be about 206.2 or less depending how much was removed. So it will be a minimum of 1mm above block.
            Add some 3mm shims instead of gasket and lightly install head measure clearance between head and piston with clay and calculate the number.
            • panose30
              • Nov 2009
              • 105
              I spoke with Wiseco and the pistons are wrong made. i try with 1mm solder and the 2.05 headgasket and it croush the solder about 0.53
              Probably a 2.6mm mls could work,but i have copper orings and i dont want to use an Mls
              Most probably i will get replacement correct pistons
              If my maths are correct with the 2.05 i have 0.47 clearance,
              so my deck height is close to 205.7-8 and 0.1 from the head.
              So to run a stock 1.75mm with the replacements pistons ,the pistons must have a compression height of 33.7 ?
              • digger
                • Nov 2005
                • 6194
                so with 2.05mm you have 0.47mm clearance then you only need CH reduced by 0.53 to give 1mm clearance, so 34.2mm if you are ok with using 2.05mm OE gasket
                or 33.9mm with 1.75mm gasket. I would aim 1.00mm clearance
                33.7mm will give you 1.2mm clearance with 1.75mm gasket
