Widest tires with rolled fenders?
  • delfin
    • Nov 2007
    • 1064
    What are the biggest/widest wheels and tires people have run with their fenders rolled?
    Advanded Delphin Division
    My e30s: 1987 325i/1994 318iT
  • z31maniac
    • 17566
    Depends on width, diameter, offset........
    www.gutenparts.com
    • atomic
      • Jun 2007
      • 5691
      although the fenders had a bit more done to them than being rolled...
      :crazy:
      • Hartge_H27
        • Jun 2006
        • 1699
        225 fit pretty good. depending on the offset of the wheel
        • gazellebeigem3
          • Jun 2005
          • 3712
          on my 318is w/ e30 m3 five lug set up with a smorgasbord of spacers, i run 245 40 17 hoosiers at all four corners with no rubbing. I dont know what size that would be on a normal tire as hoosiers tends to run big.
          • Lurker27
            • 821
            The biggest I tend to see without pretty extreme measures is 245
            '89 335is +turbo
            • Jordan
              • 12913
              235/245 is a safe bet with the right offsets.
              Much if any larger than that is going to require some alteration to paint and body work.
              https://mtechniqueabs.com/
              • StereoInstaller1
                GAS
                • 22679
                I think a 315/30/18 would fit with only slight lift
                Closing SOON!
                Thanks for 10 years of fun!
                • daniel
                  • 6703
                  someone needs to run some 345/25-18's or something.
                  http://instagram.com/dslovn.drives
                  • blunttech
                    • 12850
                    i ran 255's on DS2's and it looked stupid but no rubbing
                    sales@blunttech.com
                    www.blunttech.com
                    Like us on Facebook
                    • xLibelle
                      • Aug 2004
                      • 2673
                      this equates to 24.5" x 10" external dimentions
                      I would LOVE to fit the Hoosier 275/35 15's under stock rolled fenders.
                      These are in 23" x 10.8" dimentions... almost an inch wider but 1.5" shorter.
                      My car is on IE3's and I want to raise it back up about a half inch all around... I think they just might fit. And we're talking about putting them on 15x9 rims.
                      • xLibelle
                        • Aug 2004
                        • 2673
                        If you want to actually look up the fitments, scan the official wheel/tire fitment thread and note down the diameter and width using tire racks spec sheets.
                        ie: http://www.tirerack.com/tires/Spec.j...irePageLocQty=
                        forget offset values, they are worthless when talking about squeezing fatties under stock fenders. the offset will be what it needs to be once the external dimentions are understood. Plus it will vary with rim width and diameter too, so that topic of discussion is moot.
                        • BeirBrennerE30
                          • 2740
                          ive always wanted to run 285/30-18 on all 4 corners... not sure what it would really take to fit them. Probably m3 style fenders that are 1"-2" wider than stock m fenders. Just imagine the grip though!
                          e30sport.net
                          '06 M3 Competition - 6-speed
                          '97 Range Rover Vitesse
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            -Andy
