M20 Turbo water cooling input & output line
  • E21M20B27
    • Jul 2022
    • 12
    Hi,
    I wonder if someone can recommend a good place where I can connect my turbo water cooling in and out line to the cooling system. Perhaps if you have some pics.
    I also have a E34 radiator which has a extra output under expansion tank to auxiliary pump. M20 radiator doesn't have this. Where is the best to connect this or should I just blank it off.
    Cheers
  • ForcedFirebird
    • Feb 2007
    • 8300
    Most people just leave the water hoses off and let the oil take care of the cooling, but in the past I have used the throttle body coolant lines.
    john@m20guru.com
    Links:
    • mikey.antonakakis
      • Dec 2019
      • 256
      I've always used the throttle body coolant lines as well, basically deleting the throttle body heater. No issues to speak of, although I don't have anything to compare to.
      • TobyB
        • 5288
        +3 for the throttle body heater. The turbo doesn't need a ton of flow.
        t
