No start fuel leaking from Air intake
  • HVDE30
    • Jan 2021
    • 11
    Hello all, I have a 1990 325i and it is leaking g fuel from the intake and seems to have no spark. Anyone have this issue.
  • It's Soda Not Pop
    • Jan 2022
    • 877
    What do you mean leaking fuel from the intake? is it leaking at the rail where it enters the manifold? What have you checked? Is it throwing any code?
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • roguetoaster
      Biggus Tippus
      • 7830
      If it's leaking fuel you need to fix the fuel leak before you do anything else. Likely leaks: soft fuel lines between main fuel lines and the injector rail; fuel pressure regulator; injector o rings.
      • HVDE30
        • Jan 2021
        • 11
        The fuel is coming from. The Intake it self not a line. Someone said on another forum check the cold start valve.
        • 82eye
          • Jan 2009
          • 2108
          you don't have a cold start valve. if it's leaking from under the intake you'll need intake gaskets. doesn't quite make sense. suspect your description is incorrect, can you get a pic of the area it is leaking from?
          • Tom Galloway
            • Dec 2018
            • 133
            Better get a fire extinguisher -
            • PEZ2
              • 50
              Well there are several no start/ no spark write ups which work well. In terms of the fuel “leak” I have run across several fuel dripping out of the throttle body causes; most recent was excessive cranking with a excessively leaking fuel injector, intake reversion with the closing of the intake valve drove liquid gas back into the plenum, Another was the diagram of the fuel pressure regulator started to fail and fuel went thru the vacuum line and into the intake manifold.
              • gazellebeigem3
                • Jun 2005
                • 3712
                oh snap ive had this happen. fuel pressure regulator diaphragm ruptured and shoots fuel in the vacuum line! fuel pooled in my intake box.
                • HVDE30
                  • Jan 2021
                  • 11
                  Thanks gonna order one tonight.
