Restoring the red button on seat belt receiver.
  • Stan
    • Jul 2019
    • 776
    Apart from disassembly and painting, any tips to restoring the red button that has faded to pink?
  • ZeKahr
    • Jul 2016
    • 508
    You can hit it with a heat gun. They make an cone-shaped tip accessory for heat guns to concentrate the heat to a small area. Make sure you’re using that
    1986 325e Schwarz (sold)
    1989 325iX Alpineweiß​ (daily)
    Greed is Good
    • reelizmpro
      • 9546
      I masked and painted/cleared mine. They are holding up well.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • D3R3K
        • Sep 2018
        • 182
        have any pictures, curious how it looks
        • jhaurimn
          • Nov 2012
          • 2224
          Heat gun, or this depending on how far gone they are. https://www.r3vlimited.com/board/for...ation?t=313368
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • Stan
            • Jul 2019
            • 776
            Originally posted by ZeKahr
            You can hit it with a heat gun. They make a o cone-shaped tip accessory for heat guns to concentrate the heat to a small area. Make sure you’re using that
            Do I need to pull the seat out first? My heat gun has 2 settings, I assume the lower
            • ZeKahr
              • Jul 2016
              • 508
              If you’re referring to the rear seat, it’s prudent to do that. Although if you’re steady and careful you can just aim the nozzle at the button. And yes start off with the lower setting.
              Greed is Good
