Hard cold start unexpected fix
  • PEZ2
    • 50
    Have been struggling with a 13 year wake up of a 90 325i. Rounded up the usual suspects ICV, O2, CPS etc with no luck. Plugs are still looking rich and cold start up is poor and needs “ foot” help for the first 15 to 20 seconds unlike my 2.9l 86e. The fix revealed itself as a fuel leak. On the 90i there is a short rubber line that connects the hard return line ( body) to the tank. The small bend it had to avoid the fuel filter collapsed to a crimp, which started to leak. It appears the crimp was enough to cause the return line to become pressurized ( the leak shot 2 feet) resulting in the FPR to be unable to dump fuel to the return line to control rail pressure. Once the 4 inch section was replaced startups are good, plugs look normal.
    Click image for larger version  Name:	6F38F0A4-BF12-47AA-ACDC-02D3A4F33744.jpg Views:	0 Size:	191.9 KB ID:	10110190
  • LindrelT
    • Oct 2022
    • 57
    Good job! At least it was cheap parts wise, just some time!
    • TobyB
      • 5219
      Oh yes, not a huge surprise- this is why a fuel pressure test is so useful...
      I found a return line blocked with sludge that way once...
      t
      • Lippy
        • Jul 2022
        • 95
        Why was it crimped? Did someone use too long a hose?
        • Panici
          • Dec 2009
          • 2382
          Glad you got it! Wouldn't have expected a damaged return line.
          '87 BMW E30 325is Turbo
          '99 BMW E36 M3 - - - '98 BMW E36 328i
          • digger
            • Nov 2005
            • 6037
            there was another thread with blocked return line and if you just looked at fuel pressure you may conclude the FPR was faulty so proper diagnosis is key
