Engine Wiring Harness Question
  • redwagin
    • Mar 2024
    • 5
    I am in the process of swapping a 2.5l from a 2.7l. My parts car had a 525 Motronic 1.3 ECU (91 vert) with the engine, but no wiring harness. Does any 2.5l Motronic 1.3 wiring harness work with my ECU and engine?
  • 82eye
    • Jan 2009
    • 2099
    there may be differences with the pinout. probably not anything you'd need. the 525 is the more advanced 1.3 ecu. i'm pretty sure any 1.3 ecu will run on the 1.3 harness 87 and up.
      • 37833
      Any M20B25 wiring harness and DME will work with your engine. Depending on the year of your E30 and the year of the engine harness, some wiring may be necessary in order to adapt the engine to the chassis. If your vehicle happens to be a 86-87 325e/es you can use the harness from a 87 325i/is and it will be plug and play.
      Grover Beach, California
      BimmerHeads.com
