Hiccup on e30s
  • Fast6ix
    • Oct 2024
    • 3
    Hiccup on e30s
    On my 87' 325is when I accelerate flat out I usually get a hiccup or two on the upper end of the tach ( 4-5 k rpm). Is this normal for e30s? If not any ideas?
  • Panici
    • Dec 2009
    • 2462
    Hiccup as in misfire?
    How old is your ignition system?
    Cap/Rotor/Plugs/Wires.
    When was the fuel system serviced? Fuel filter replaced?
    '87 BMW E30 325is Turbo
    '98 BMW E36 328i
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5545
      Not normal
      most likely due to something failing in the spark ignition system
      I had an issue in the past of higher RPM hiccups and it was due to a fouled plug..
      I'd start by pulling each plug and checking for built up shit on the tip.
      • TobyB
        • 5251
        AFM can do that, too...
        t
