M20 Intermediate Shaft Bearing Cover Gasket?
  • marquis-marc
    • Mar 2024
    • 20
    Hey all,
    In the process of putting back together my M20.
    Looking for info on the "Gasket Ring" found on real oem #24 on this page.
    https://www.realoem.com/bmw/enUS/sho...diagId=11_0119
    12111363190 is NLA and I believe the engine was leaking from this spot prior to the rebuild.
    If anyone has experience with this gasket that would be much appreciated!
    - Is the gasket the black ring shown in the photo below or is there a 2nd gasket that goes somewhere else along the bearing cover?
    - Has anyone used a generic gasket/one from another model in the place of 12111363190?
    Thank you!
  • 82eye
    • Jan 2009
    • 2094
    it's just an o-ring. i used generic o-rings from an o-ring kit in a lot of places on the car.
    • marquis-marc
      • Mar 2024
      • 20
      Thanks for the reply! I realize I'm probably overthinking all this, but it's my first engine build and I'm getting a little carried away.
      What I wasn't sure of is whether the ring I have labeled in the below Picture as "B" is included along with the Bearing Cover or not.
      Would appreciate clarification on 12111363190, the O-Ring I'm overthinking: Is it replacing "B" or is to be installed in location "A" making "B" a different part all together?
      • 82eye
        • Jan 2009
        • 2094
        dunno what you are on about. it's an o-ring. there isn't anything else down there. i replaced the needle bearings and rebuilt the oil pump during my engine build.
        • digger
          • Nov 2005
          • 6176
          i have seen it listed as a 50 x 2.4 o-ring
          there is no picture showing in post #3 so we have no idea what you are referring to
