Trunk lock actuator frozen - convertible
  • nadodude111
    • Jul 2009
    • 432
    Hey guys hoping someone has run into this problem and had a solution.
    The trunk lock actuator in my convertible is frozen and I can’t open my trunk. Being a convertible, I can’t kick in the ski pass, so how do I open the trunk to replace the actuator?
    Actually all actuators are frozen, but at least I can get access to the two front doors to replace those.
    thanks!
    1992 325i Convertible
  • ehrawn
    • Aug 2023
    • 222
    I’ve not had this problem, yet (thankfully), but you might be able to get to the mechanism through the hole for the license plate light with a bent wire.
    • 82eye
      • Jan 2009
      • 2087
      dunno if this works - see if your gas tank door cover is unlocked and the gas tank door is open. if it is, depress the lock. it should unlock the trunk. old trick i read about in another forum on 80's bmw.
