Determining duty cycle/injector opening time?
  • E30godz
    • 1524
    alright, lets see if my reasoning makes sense to others:
    im having trouble getting these 30l# fuel injectors to work in my car, even with the SMT-6
    so heres my solution:
    ok, so the stock fuel injectors are 14#ers, if i can figure out the pulse width at idle, i can then see how much fuel is being delievered ( 14#/hour/ 60 minutes/ 60 seconds/1000 (to get milliseconds). i can do the same for the 30 pounders and then set back the voltage accordingly so the same amount of fuel will be injected.
    good? bad?
  • Digitalwave
    is a poseur
    • 6298
    Why they hell do you have 30# injectors if you want them to deliver the same amount of fuel that the stock ones deliver?
    Maybe I am understanding that wrong.
    RISING EDGE
      • 34839
      the problem is 30# injectors are way out of the range for the ECU. remember, the SMT6 can only work within the limits of the ECU. get smaller injectors already!
      • E30godz
        • 1524
        well...i got them to work once...like the first time i ever tried and it worked without a hitch..but then i started fucking with the AFM adjustment screw and the car stopped running, so to get it running again i swapped in some 19's...i tried several more times to get the 30's working after that (probably 4 or 5 installs) with no luck...crazy.
        so i know thats not the case.
        TCD informed me that a guy had 42lbers working with the SMT-6
        Digital, im only looking to get the car running with them, and since they will be running at very low capacity, i'll have a lot to work with. I'm wireing the primary injectors to a map sensor so it will add fuel dependent on boost ala rising rate fuel pressure regualator...but more lik pulsewidth increasing with boost fuel giving device ; )
        can anyone answer my question?
