I want a quiet exhaust
  • TwoJ's
    • Oct 2005
    • 4908
    ... relatively.
    My stock exhaust has a leak that I can hear, and I want my car to sound better. I don't really want a loud exhaust. If I did i would just buy the cheap chinese (IE) cat back. I want something that sounds stock, or even a new stock exhaust. So what should I do? My car is completely stock and it will likely stay that way for a while.
    I'm hesitant to go for a used exhaust because I"m afraid that it will sound like mine. Mine looks good, so I can't really tell how it will sound by just looking at a used exhaust. I can weld and have access to any type of welder I want. If I were to do my own exhaust, what muffler do you people recommend? We don't have to pass emissions here and don't have inspections so should I even bother with a cat? Will catless with a quiet muffler be loud?
    Thanks for any tips.
    • 34839
    a new OE muffler is cheap. the expensive part would be the cat - does your cat section leak? if you remove the cat the car will most definitely be louder, and likely smell like fuel.
    • TDE30
      • 7042
      I share similar thoughts in regards to my current Magnaflow 14815, it has an alright note when blasting around town, but 90% it sounds monotone and loud.
      Please post up a price and maybe a sound clip or two if you opt for a new OE unit, I'd really appreciate it.
      - Trey
      E90 325i/6 (ZSP, ZPP, ZCW)
      E36 325i sedan
      E30 325i sedan
      Volvo 945T
      • TwoJ's
        • Oct 2005
        • 4908
        Yeah, after thinking about it I don't think I'd leave the cat out. The cat is actually the worst looking part of the entire system, but I actually don't know where it is leaking from. It's up on stands now so I guess I should just give it a good looking over and see if I can get away with just replacing the cat and muffler.
        • TwoJ's
          • Oct 2005
          • 4908
          I just looked at factory cats and I can tell you this is definitely not the route I'll go. I refuse to drop $450+ for a cat. I'll keep looking, but I may just have to find a used one in good condition..
          • Tbolt
            • Nov 2007
            • 1165
            my stock exhaust has a nice note to it
            Tbolt Division
            All I'm saying dude is that bird law in this country...it's not governed by reason.
            • TwoJ's
              • Oct 2005
              • 4908
              Ok?
              • viali8
                • Nov 2005
                • 673
                For what you are describing i would highly recommend a eberspacher.
                Sounds like stock but has a nice rumble to it. There is no droning when driving...very similar to stock. it is not loud at all...you will not be disappointed.
                good luck
                • woodisgood
                  • 1087
                  Sounds like stock but has a nice rumble to it. There is no droning when driving...very similar to stock. it is not loud at all...very similar to stock...you will not be disappointed.
                  good luck
                  Do you install two of them?? Isn't the stock muffler 2 in 2 out?
                  • Asbradley21
                    • Jun 2008
                    • 1938
                    I'm probably about to pull the cat off of my 318, if you want it.
                    S54B32 swap in progress. Status: Getting There
                    • viali8
                      • Nov 2005
                      • 673
                      muffler
                      Not sure what you are asking.
                      Yes I am referring to the one piece cat back muffler which is 2 in 2 out.
                      • '90 325is
                        • Jan 2009
                        • 230
                        performancepeddler.com has pretty cheap cats. check it out
                        PNW CREW
                        1990 325is
                        Scorpion exhaust
                        K&N intake with signature motoring heat shield
                        H&R race with bilstien sports
                        D-Force wheels/Hankook Ventus RS-2's
                        • TwoJ's
                          • Oct 2005
                          • 4908
                          If it is in good shape and not leaking I will take it off your hands. It doesn't matter if the flanges are the same as mine, I can make some and weld them to the exhaust. Thanks.
                          And thanks for the ideas guys, I'll look in to them right now.
                          • Asbradley21
                            • Jun 2008
                            • 1938
                            Alright, I'll hit you up some time next week probably. Once I pull it, I'll make sure it's in good shape (I know it doesn't leak, but the heat shield might be coming off. Easy fix.) Car is at the body shop until Friday, It goes to the exhause place monday/tuesday.
                            • daniel
                              • 6703
                              i think you should just get a generic cat and order an OE muffler, have a muffler shop fit them in nicely, done.
                              http://instagram.com/dslovn.drives
