How much is my M20 worth?
  • markseven
    • Sep 2006
    • 5327
    How much can I get for a complete M20?
    Past two years maintenance:
    October 2007
    Flushed the coolant with BMW coolant
    April 2008
    Timing belt, cam seal, and cam flange O-ring
    Water pump
    Valve adjustment
    May 2008
    Fan clutch
    September 2008
    Fuel pressure regulator
    Distributor rotor and cap
    Plug wires
    Motor mounts
    Dyno:
    148 whp
    148 wtq
    I Timothy 2:1-2
  • devonjordan
    • Jul 2006
    • 2386
    Hey mark, don't think they are worth much... couple hundred maybe? See you tomorrow.
    Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
    Help a brother out, buy your detailing products here...
    • george graves
      • 20003
      250-400. Might consider parting the motor and junking the block.
      Originally posted by Matt-B
      • bimmer_E30
        • 5001
        part it out...
        i will take the fan clutch.
        Originally posted by e30e
        • AlarmedBread
          • Sep 2006
          • 1510
          Do not sell it on r3v unless you got it free.
            • 34844
            it might be worth something to one of the spec guys.. sounds healthy at 148whp.
            • markseven
              • Sep 2006
              • 5327
              Yeah, that seems to be the going rate
              Dev, see you in an hour.
              Originally posted by bimmer_E30
              part it out...
              Great idea. That's prolly what I will do. Fan clutch is yours if/when.
              :up: :up:
              I Timothy 2:1-2
              • markseven
                • Sep 2006
                • 5327
                Hmmm... interesting option. Yup, 148 with the TMS chip. The TNG guys will run a compression check - I'll have numbers soon.
                I Timothy 2:1-2
                • StereoInstaller1
                  GAS
                  • 22679
                  Pop that thing on CL, I bet you could get $450 easy, but post it at $650
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • markseven
                    • Sep 2006
                    • 5327
                    I forgot about CL! Thanks Luke.
                    I Timothy 2:1-2
                    • kishg
                      • Sep 2006
                      • 2624
                      s5x time mark? that m20 sure looks clean.. that ought to bump up the value :)
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                      • markseven
                        • Sep 2006
                        • 5327
                        Kish, yes sir, I have a S52+trans+diff out of a '99 M Coupe ;) The engine is clean and strong... hate to see it go.
                        I Timothy 2:1-2
                        • kishg
                          • Sep 2006
                          • 2624
                          buy a 2002 and swap the m20 in :)
                          '91 SpecE30 #523
                          128290
                          • markseven
                            • Sep 2006
                            • 5327
                            rofl!
                            I Timothy 2:1-2
                            • Liam
                              • 753
                              Me... I think the m20 is priceless but if you want to convert them to cash you're better served by getting a quick part time gig at Taco Bell.
                              I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
