Allen Bolt holding the Rotor
  • masayahin
    • Nov 2008
    • 96
    I destroyed the allen bolt holding both the front rotor and thread is gone for both (had to drill them both as PB Blaster is no match even soaking them overnight).
    My question is it okay to disregard the allen bolt and use the caliper to just hold the new rotor in place or do I need to purchase the wheel hub?
    thanks for any input.
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    It should be fine.
    Yours truly,
    Rich
    you kids get off my lawn.....
    • DarkWing6
      • Apr 2004
      • 7144
      Correct me if I am wrong, but I believe the allen bolt is only for holding the rotor in place while you mount your wheel. The lugs should hold things in place, but it will be a huge PITA to mount your wheels unless you have studs.
      • Dave
        E30 RAT
        • 11675
        the brake caliper and pads will hold it in place pretty well.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          You're fine. Commence with your life.
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • delatlanta1281
            Dart Master
            • Mar 2006
            • 10317
            It could be....
            What I do is use the wheel mounting tool in our tool tray on the first lug. Then after that, it's gravy. Just don't hit the put on the ebrake, it will move the hat and mis-align it with the hub.
            Yours truly,
            Rich
            • Fidhle007
              • Oct 2005
              • 7209
              Originally posted by delatlanta1281
              It could be....
              You have an e-brake on your front wheel? Baller! :p
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                Rear, and as far as I am concerned, your fiddle would make an excellent wheel chock in a pinch.;)
                Yours truly,
                Rich
                • Fidhle007
                  • Oct 2005
                  • 7209
                  You know, you can say what you want about me and my car but my violin is worth more then most of the cars on this board. Combined. It is an exquisite instrument of 1940's german craftsmanship and has nothing to do with me personally except that I play it. You want to make fun of my music, fine. You want to make fun of my car? Even better. Leave the instrument out of it, dickwad.
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    And just so we're clear, the OP asked about his front hub and you brought up the ebrake...
                      • 34844
                      it's not a big deal to use the rotor set screw if you use anti seize and don't he-man the things on there. finger tight is plenty, but for some reason I imagine people getting out their breaker bars and torquing them down until they almost pass out. Never had a problem getting one back out and have even been able to reuse a few.
                      • for3ver
                        • Apr 2007
                        • 329
                        Same thing happened to me, like everyone else said you'll be fine without them. I've driven about 5,000 miles without them and had no problems.
                        • Beach Bum
                          • 466
                          I believe he was simply joking. Calm down. As a musician, you should be used to the riff-raff making fun of us as an attempt to make it seem like they are somehow better than musicians.
                          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                          • masayahin
                            • Nov 2008
                            • 96
                            Thanks to all for the feedback.
                            Also, I just got this car and those allen bolts are like not been removed since...
                            Looking at the rotors, they probably just keep on changing the pads without changing the rotors? pads are ok but rotors are really warped out, grooves are really deep and never seen so much rust in a rotor.
                            I'll be doing the rears, so what are other anti-seize products other than PB Blaster before I use my drill again? TIA
                            • monticello
                              • Sep 2007
                              • 202
                              impact drivers work excellent. if they're that bad you may have to use some heat. the only reason the screws are there are to keep the rotors from falling off while the car goes through the assembly line.
