Allen Bolt holding the Rotor
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    Originally posted by Beach Bum
    I believe he was simply joking. Calm down. As a musician, you should be used to the riff-raff making fun of us as an attempt to make it seem like they are somehow better than musicians.
    I believe fiddle was joking as well. Being a member of r3v, you should be used to a certian level of sarcasm. :D
    Yours truly,
    Rich
    you kids get off my lawn.....
      • 34844
      Originally posted by masayahin
      Thanks to all for the feedback.
      Also, I just got this car and those allen bolts are like not been removed since...
      Looking at the rotors, they probably just keep on changing the pads without changing the rotors? pads are ok but rotors are really warped out, grooves are really deep and never seen so much rust in a rotor.
      I'll be doing the rears, so what are other anti-seize products other than PB Blaster before I use my drill again? TIA
      you have to use the anti-seize before you put them in, it keeps them from getting stuck. for now you'll have to use PB Blaster, and hopefully you have access to an impact.
      • Charlie
        kid tested, administrator approved
        • 6686
        Dremel it into a flathead, use a big screwdriver. Problem solved.
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
        • scabzzzz
          Estado de mierda de encargo
          • 6871
          Ive broken every single one I've touched. Fuck em you dont need em
          • Radimir Shittskova
            • 30
            drill hole in said bolt, insert easy out bit, easy out that bish, replace with new 25 cent bolt.
            • Turf1600
              • 9815
              x2. I have a drilbit I bought for these.
              • FredK
                • 14763
                Wow. It should be easy as pie to remove the set screw from a car from TX.
                For those cars that have been driven in the harsh winters of the Northeast, you will likely need a torch and an impact driver--one of those manual drivers that you attach a screwdriver or allen bit on one end, and hammer the other end.
                • Naplm00
                  • Nov 2008
                  • 1573
                  I have a bag of these from the dealer....that being said, i just always baste it in anti-sieze and i dont have an issue
                  88 325ic ~~~> Rusty and ugly
                  85 E ~~~> RIP
                  • Fidhle007
                    I can fly, motherfucker
                    • Oct 2005
                    • 7209
                    Fuck you, I was being serious! I'm going to go tweet about how mean to me you are.
                    :D
                    '89 325is S50 Track Montser
                    '04 X5 Daily/Tow Vehicle
                    http://www.avarestoration.com
                    http://www.myspace.com/brendanfiddle
                    Click here if you want to be my zombie slave...
                    http://www.youtube.com/user/Fidhle007
                    • delatlanta1281
                      Dart Master
                      • Mar 2006
                      • 10317
                      I already tweeted what a douche nozzle you have turned into over the past two hours.
                      Yours truly,
                      Rich
                      • Fidhle007
                        • Oct 2005
                        • 7209
                        You mean MORE of a douche nozzle. :D
                        • wodcutr
                          • Apr 2009
                          • 2193
                          The drama is most amusing!
                          The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
                          • ldsbeaker
                            • Aug 2004
                            • 3098
                            My car didn't have it (surprise from PO!!), but I never knew the difference.
                            Slicktop City!
                            • bataangpinoy
                              • Jul 2008
                              • 1636
                              this.
                              but its a freaking pain to re install the calipers w/o said bolt.
                              My feedback:
                              http://www.r3vlimited.com/board/showthread.php?t=186328
                              http://e30tech.com/forum/showthread.php?t=74911
                              Instagram:
                              @gears_n_glory
                              @functionmotorsports
                              • Fidhle007
                                • Oct 2005
                                • 7209
                                Originally posted by bataangpinoy
                                this.
                                Yeah it is, you have to actually use BOTH hands...
