Yet another car!
  • deutschman
    • May 2008
    • 5958
    Yet another car!
    Looks like you guys may be dealing with me for a bit longer after all. One of my mothers rich clients just offered me their '84 325i 2 door 5 speed. I would rather have an e30 right now than a 2002 so if this works out I think I will have to tell the guy I was going to get the '74 from that the deal is off. I really want an m20. I am really ready to move on from m10's and m42's! I hope this works out! If it does it will be time to start looking for a plastic bumper swap parts in the pick-and-pull yards around my area and the forum.
    The car has been in the family sins it was bought, and has recently had a new motor installed and has always had regular maintenance. I think this car will = win. I think I will be taking a look at it on Friday. I will post some pictures then.
  • red325
    • 961
    Nice. E30>2002
    • deutschman
      • May 2008
      • 5958
      here is a copy of the email i just got from the owner. sound like a really nice car for her age.
      I plan to go and pick her up on Wednesday, I'll let you know how that
      goes. The battery is probably dead or too low to start.
      She is a grey ("Delphin") two door E30 with approximately 275K miles
      overall but the engine is newly rebuilt as of 260K miles. She was last
      driven a few months ago and is current on smog and registration.
      Because of the newly rebuilt engine, there may be some extra hoops to
      pass the smog inspection; for the last few years I had been going to the
      Bureau of Automotive Repair test station at Skyline College. They have
      since given me the special sticker (in the driver side door well) that
      allows a regular test only station to test the car. I believe that my
      last smog was done at a station around the corner from me.
      Many of the components that wear down in a car this age have been
      replaced, the hardy disk is new; I believe the transmission and clutch
      have been recently serviced as part of the engine tear down but I will
      have to check. My family has maintained possession of the car since she
      was new and to the extent that my sisters and I can pass files back and
      forth for 25 years, I have the entire service history.
      The catalytic converter was replaced with an OEM, non-BMW part and she
      sounds a little different than you might expect.
      She has no major structural or mechanical defects that I can verify, but
      there is an outstanding issue with the driver side rear. I believe she
      needs a new strut, shock tower or ... something, but I have not looked
      into what that is yet. There is a dent from when she was parked on the
      street, but I do not know if there is underlying body damage.
      The front spoiler is missing. I believe it was torn off in a snow bank.
      Adding back the front spoiler makes a difference of about 1-2 MPG.
      A common problem with the early E30's is that the trunk accumulates
      water. I recently drilled a small hole in a plug in the bottom of the
      battery compartment and the trunk has stayed dry after that.
      For a time, I had a problem with the speedometer sensor dropping to 0
      while driving. I have since narrowed this problem down to the solder
      connections on the Service Indicator Board. I went through and
      re-soldered the major contacts and the problem went away. The battery
      on the SIB died and I replaced it with a battery holder and NiCds, which
      have since also died. You will need to get a reset tool to reset the
      service indicator lights, but they will stay correct unless the battery
      dies.
      The engine thermostat gauge works intermittently. I believe it is the
      temperature sender but I am not sure. As for thermostat function, the
      engine feels like she is operating at the correct temperature.
      We are on our third radio. The antenna drive has been rebuilt by me,
      and she probably needs a new antenna mast to get full range of motion.
      There is a car alarm wired up, but it was not very reliable and the fuse
      has been pulled from it. I am not sure where the remote control is at
      this time.
      I added two cigarette lighter plugs, one in the well behind the parking
      brake and one under the passenger seat. These are for charging mobile
      phones or what have you. For a while I had an inverter plugged in so
      that I could plug in a laptop.
      One of the seats does not flip forward properly to allow access to the
      back seat. It feels like the cable needs to be re-attached to either
      the release lever or the seat. A small fix, but I have not looked into it.
      The glove compartment does not open. The handle is broken so it does
      not pull the release mechanism. If you get it open, I would like the
      contents of the glove compartment. I believe that there is at least one
      pair of sunglasses trapped in there.
      I installed new door and sunroof seals so she is much quieter now on the
      highway than a typical 25 year old E30.
      I believe that she has two new tires, although I may have replaced all
      four, I do not recall.
      I will pass along my Bentley manual unless you already have one (I have
      a friend looking for a copy), and a copy of the Mobile Traditions CD
      once I find it again in my mountain of boxes.
      She is a great car that is aging gracefully. I have many fond memories
      with her. She followed me to college and back and has very reliably
      taken me on many trips to the mountains. She has outlived a new BMW
      that had recurring transmission problems and a new VW that was returned
      under the lemon law.
      She has her quirks, and so I do not feel comfortable passing her on to
      just anyone. She will tell you everything you need to know, but you do
      have to listen to her.
      • daniel
        • 6703
        M42>m20
        http://instagram.com/dslovn.drives
        • Jean
          • 18228
          I didn't think they had 325i model in 84? Didn't it come out in 86?
          Are you sure it's not a 325e? Those were out in early 84. Or is it an E with an I engine?
          • Wh33lhop
            • 11705
            That was my first thought. There were no genuine 325i's before the '87 model year, unless it was imported (IIRC).
            Originally posted by daniel
            M42>m20
            Ultimate lies! :p
            paint sucks
            • Alkasquawlik
              • 4557
              M42>m20
              Go crawl back into your hole.
              SC*AR
              Originally posted by JamesE30
              And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
              • Danny
                • 14216
                I liked my M42 better than my M20.
                • jflip2002
                  • Sep 2006
                  • 4377
                  Yeah, 84 was just a 325.
                  Originally posted by blunt
                  • tg318is
                    • Jun 2008
                    • 2052
                    meee toooo
                    Tim.
                    • naplesE30
                      • Nov 2007
                      • 1839
                      m42 FTW TIMMING CHAIN need I say more!
                      • Ben Carufel
                        • Jun 2004
                        • 5248
                        I have a set of front and rear plastic bumpers if you need some. Just about mint condition, brilliantrot. With brackets, shocks, etc.
                        • deutschman
                          • May 2008
                          • 5958
                          M42>m20
                          i actualy realy liked my m42 but in have never owned a 6er so i wont to have one. enough said.
                          i think he put an i engine in it when he replaced the motor. but thanks for pointing that out! that little fact never realy crossed my mind. ill check for that.
                          i'd love them but i dont have the extra money right now. thanks for offering them and good luck selling them man.
                          • Edev
                            • 3731
                            Pics.
                            M Coupe
                            • deutschman
                              • May 2008
                              • 5958
                              pics coming this week some time.
