Rear Gears
  • FredK
    • 14755
    Around 2500 rpm with a 3.25, 2250 with a 2.93. A G240 has an overdrive 5th.
    • Wh33lhop
      • 11705
      At 65, if you were turning over 3500 before with a 3.73, you're looking at 3050 with the 3.25 and 2750 with the 2.93.
      However your numbers do not seem in line with a stock tranny and 3.73 rear end.
      paint sucks
      • FredK
        • 14755
        Um, yeah, I should have used proportions rather than a gear calculator. Oops. :D
        • threlevenguy
          • Dec 2006
          • 1057
          Right on, 2.93 sounds good. That second ebay link that I posted -- That bolts right up with that case correct?
          • Wh33lhop
            • 11705
            It should.
            If I were you I'd take a gander at my rear end though (no homo), doesn't sound like you're running a 3.73. Sounds more like a 4.45.
            paint sucks
            • NC325iC
              • Mar 2004
              • 6565
              2.93 would be good for highway cruising but your gonna loose some of the fun acceleration
              • threlevenguy
                • Dec 2006
                • 1057
                Hmm...I gota have some fun. The 2.93 isn't fun at all?
                • rThor432
                  • Feb 2007
                  • 3907
                  I have a 2.93 in my car it is still quick, but I wouldnt mind having a bit more gear back there. All I do now is highway driving, so it makes sense. I average ~32-33 mpg. The 3.25 would be easy to find and ideal for mixed driving.
                  • threlevenguy
                    • Dec 2006
                    • 1057
                    What did the 3.25 come in?
                    • Wh33lhop
                      • 11705
                      Which engine and tranny are you running though? If you're running an E36 transmission a 2.93 would be fine, but with a G260 or G240 with a .81 5th gear it's going to be very tall.
                      I'm still not convinced the OP is running a 3.73.
                      paint sucks
                      • Rigmaster
                        • 3464
                        3.25 is about the only commonly available diff that will bolt in (found in several different E28's). Most people say a 3.46 or 3.64 is ideal, but they're really hard to find in an E30 case.
                        No offense, but most of the stuff you're asking has been covered over and over and over again. Try a search, not just here but maybe bfc.com too....??
                        3.25 diffs are found in some E28's, specifically the ~82-84 533i, but IIRC it's also in some of the later 528e's- but not all.
                        And to answer another question someone posed about 3.64's being common in the early 318i's, yes- that's true, but those are small case diffs and we're dealing with medium case diffs here.
                        • rThor432
                          • Feb 2007
                          • 3907
                          I got two of them from dogleg trans equipped 323i's. But those dont grow on trees. Like Rigmaster said..
                          I'm running the S52 with the G260. I turn around ~2k rpm @ 65.
